February 24, 2011, 09:55 |
wind turbine, actuationDisk
siri
Rep Power: 16 |
I'm trying to simulate a wake with actuationDisk approach and have used the tutorial turbinSiting as a starting point. I' m using snappyHM to create a mesh over a flat stl-surface but I have not succeeded meshing the disk. I get this message when running simpleWindFoam;
Selecting model type actuationDiskSource Source: disk1 - selecting cells using cellSet actuationDisk1 - selected 0 cell(s) with volume 0 Everything is the same as in the turbinsiting-tutorial, except that I have changed the domain and used a flat stl-surface instead of complex terrain. I do not understand what is wrong, anyone with similar experience? Siri |
March 3, 2011, 08:16 |
siri
Rep Power: 16 |
I had just forgot settingthe right coordinates in makeZone file! Now it works fine :-)
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 03:53 |
[snappyHexMesh] 2D wind turbine airfoil (snappyHexMesh OR blockMesh) | openfoam1 | OpenFOAM Meshing & Mesh Conversion | 0 | January 5, 2010 03:15 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 03:12 |
Wind turbine simulation | Saturn | Main CFD Forum | 1 | June 12, 2006 04:57 |
