February 22, 2011, 08:03 |
Plot of the turbulent viscosity
Girolamo
Rep Power: 16 |
i would like to plot with parafoam the turbolent viscosity on my Omera M6 wing. I made a case with the Spalart-Allmaras turbolent model and i can obtain the plot of the nut easily. now i'm trying to use the k-omega model, but in parafoam i have nut=0 so i don't have any plot. which parameter should I choose to view the turbolent viscosity on my wing??? thanks very much p.s. i have also u=0 in the paraview menu!!! |
February 26, 2011, 06:17 |
Claus Meister
Rep Power: 18 |
On the Wing (Wall) itself are these values zero: nut - because of the boundary layer and U by definition.
February 26, 2011, 16:00 |
Girolamo
Rep Power: 16 |
ok, thanks
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 18:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 13:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 01:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
