Submarine with SimpleFoam
Old   February 25, 2011, 07:34
Vesselin Krastev
vkrastev is on a distinguished road
Originally Posted by alex_rubel View Post
I'm doing a yaw angle study for my high Y+ model and the result are quite consistent I don't think I can improve a lot this model. I'm gonna try Kepsilon And Komega but my experiment on my case with CFX shows me that KomegaSST is the more accurate
Alex
The k-omega standard model should not give you any improvements compared with the SST one. Among the k-epsilon family, I advice you not to use the standard model (which is not suitable for external aerodynamics flows). Try instead the RNG or (better) the Launder-Sharma k-epsilon (but the latter needs a low y+ mesh). Try also (for high y+ computations) the Spalart-Allmaras model with nutSpalartAllmarasWallFunction for nut at the wall.
Regards
V.
vkrastev is offline   Reply With Quote
komegasst, simplefoam, submarine, wallfunction
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 17:34
simpleFoam ddt Euler ? Mo-ITB OpenFOAM Running, Solving & CFD 2 June 12, 2010 14:36
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 04:08
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 10:42
