grid length scale in DES Spalart-Allmaras - definition of dTilda
Old   February 2, 2011, 17:14
Default grid length scale in DES Spalart-Allmaras - definition of dTilda
fsaltara is on a distinguished road
Does someone know how is calculate the grid length scale used in dTilda? In the original model, Spalart proposed to use the maximum length of the cell, but in the lesdelta options I was unable to find something similar. I am using the cube root delta.
fsaltara is offline   Reply With Quote
Old   May 16, 2012, 19:50
0.1 watts is on a distinguished road
Looking through the src it seems that the user is restricted to the usual LESDelta options.
One of the other options is maxDeltaxyz: 'Maximum of x, y and z; for structured hex cells only'.
Is this equivalent to the DES Delta parameter, and if so does it work with snappyHexMesh grids?
0.1 watts is offline   Reply With Quote
Old   May 17, 2012, 05:53
Vesselin Krastev
vkrastev is on a distinguished road
Until OF-2.1.0, the Spalart-Allmaras DES delta definition (max DeltaX, DeltaY, DeltaZ) was not available, so the only reasonable choice appeared to be the classical cubic root Delta definition (which, however, does not return the expected behavior in the RANS zone of the original S-A DES model). Now it seems that someone has detected (at last...) this deficiency, so the maxDeltaxyz is the consistent choice for the DES model in its original form (although "consistent" does not mean "best", especially in the LES region of the flow with highly anisotropic or unstructured grids)
Regards
V.
vkrastev is offline   Reply With Quote
Old   May 17, 2012, 07:35
Thanks for your advice, I'll try both with DDES and see what the differences are.
Old   July 17, 2012, 06:07
Anne Gerdes
Anne Lincke is on a distinguished road
Dear all,
I have a question concerning the computation of (max DeltaX, DeltaY, DeltaZ) in
src/turbulenceModels/LES/LESdeltas/maxDeltaxyz.
Here are some lines of the code
HTML Code:
 forAll(cells,cellI)
        scalar deltaMaxTmp = 0.0;
        const labelList& cFaces = mesh().cells()[cellI];
        const point& centrevector = mesh().cellCentres()[cellI];
        forAll(cFaces, cFaceI)
            label faceI = cFaces[cFaceI];
            const point& facevector = mesh().faceCentres()[faceI];
            scalar tmp = mag(facevector - centrevector);
            if (tmp > deltaMaxTmp)
                deltaMaxTmp = tmp;
        hmax()[cellI] = deltaCoeff_*deltaMaxTmp;
To my understanding, the method takes the maximum from faceCentre to cellCentre, for each cell.
But in order to obtain the desired (max DeltaX, DeltaY, DeltaZ), isn't it necessary to multiply the obtained value with a factor 2?
Is it necessary to set deltaCoeff to 2 in constant/LESProperties? As far as I can see the default value is 1.
I would appreciate any answers.
Kind Regards
Anne
Anne Lincke is offline   Reply With Quote
Old   July 24, 2012, 06:07
David GISEN
David* is on a distinguished road
Hi Anne,
if you are using Hexamesh, you have to set deltaCoeff to 2 to obtain the correct value. As far as I understand, it is implemented in the present way to account for Polymeshes. There is a bug report (ID 0000474) at http://www.openfoam.org/bugs/ including this topic.
Regards,
David
David* is offline   Reply With Quote
Old   July 25, 2012, 11:23
Anne Gerdes
Hey David,
thank you for this hint. I found this thread a while ago, but could not find it anymore.
Kind Regards
Anne
Old   August 1, 2012, 06:30
Anne Gerdes
I have one small further question.
Citation from the Bug report site
In case of polyhedral meshes it is easier to calculate the distance between the face centres and the cell centre. In the particular case of hexa you can just use the coeff for maxDeltaxyz to get the max(h) from face to face on the cell:
maxhxhyhzDeltaCoeffs
deltaCoeff 2;
The same with IDDESDeltaCoeffs, you can use deltaCoeff_
IDDESDeltaCoeffs
deltaCoeff 1;
cw 0.15;
Doesn't it has to be
IDDESDeltaCoeffs
deltaCoeff 2;
cw 0.15;
when using hex meshes?
Kind Regards
Anne
Old   May 27, 2013, 17:28
MaryBau is on a distinguished road
Hi everyone;
Does anyone know the answer to Ann's previous question about how to define deltaCoeff for hex meshes?
I believe that when using DES or DDES:
maxDeltaxyzCoeffs
deltaCoeff 2;
but for IDDES the deltaCoeff should be defined as 1. So:
IDDESDeltaCoeffs
deltaCoeff 1;
cw 0.15;
Is that correct?
Thanks for your help.
MaryBau is offline   Reply With Quote
Old   December 11, 2014, 05:48
Andy_bm is on a distinguished road
This question is actual for me. I use LES turbulence model and snappyhexmesh. What is the delta should I choose 1 or 2? Because there is the problem of the flow past cylinder. If Deltacoeffs = 1 then Cd = 0.33, if deltaCoeffs = 2 then Cd = 1.2 as in the experiment. But I have coarse mesh y+ ~ 40, V=72m\s
Thanks.
Andy_bm is offline   Reply With Quote
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 06:59
grid generation for Detached eddy simulation (DES) ROOZBEH Main CFD Forum 1 June 18, 2007 13:02
Kolomogorov length scale Bobby Main CFD Forum 8 November 23, 2002 04:54
Structured Grid Definition craig shores Main CFD Forum 3 March 21, 2001 15:48
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
