inlet pressure not conform measurements
Old   February 1, 2011, 19:29
Default inlet pressure not conform measurements
Wouter van der Meer
wouter is on a distinguished road
I used simpleFoam to calculate the inlet pressure of a nozzle.
I set the inlet water velocity and I hope to verify the necessary pressure to get this flow through nozzles of different configurations. For one configuration I have measurements of this pressure. OF gives me pressures of 300 N/m2 while 0.2 bars =2000 N/m2 is measured.
wouter is offline   Reply With Quote
Old   February 14, 2011, 08:26
Default solution found
Wouter van der Meer
In another post I found the solution to my problem.
I have to multiply the calculated values with the density of the fluid (1000 kg/m3 for water). Now the calculated values are in accordance with the measured values.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 22:32
How to give pressure inlet in Fluent Vijayaragavan FLUENT 2 December 13, 2007 04:21
about pressure inlet boundary Sastry(CFD Forum) FLUENT 0 February 19, 2007 03:55
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
