GGI initial value definition: any effect?
Old   January 27, 2011, 23:09
Default GGI initial value definition: any effect?
Robert
lordvon is on a distinguished road
Just a quick question...
I realized I accidentally defined values for patches of type ggi (i.e., uniform(6.8 0 0),etc.); this should be ignored by the solver, right?
lordvon is offline   Reply With Quote
Old   January 27, 2011, 23:51
Kurne
kurne is on a distinguished road
Dear
Will you please tell me How GGI is done in the Open FOAM? I am using Open FOAM 1.7.1 whether it is possible in this version.If not then which version should i use and from where should i get the extension files.If you have then please post it or tell me the procedure for that too.I am really in need of that.
Thanks In Advance.
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
Old   January 27, 2011, 23:58
Robert
Sure. I am pretty sure OF 1.7 does not have GGI capability. What you want is OF 1.5-dev or 1.6-ext. The installation was very easy for me following these instructions: http://openfoamwiki.net/index.php/In...ucid_10.04_LTS in section 2.3.2. I got a new computer and was able to install in no time. I have Ubuntu 10.04, I believe they dont work on Ubuntu 10.10, which is the latest version. I am not too sure of the differences between 1.5dev and 1.6ext, I have 1.5dev, but they both can do GGI. Hope this helps. Oh, and for setting up the case you can start from the 'mixerGgi' tutorial files.
Old   January 28, 2011, 00:17
Kurne
Dear Lordvon
Thank you very much for giving me valuable information.This things i am searching from last couple of days i will try to install it.Hope it will work.
Best Regards
Mubeen K Kurne
Old   February 24, 2011, 03:46
Kurne
Dear Lordvon
Will you please tell me that to install and run OpenFOAM 1.5-dev first we need to install OpenFOAM 1.5 and then OpenFOAM 1.5-dev.If this is correct then i am unable to get source pack of OpenFOAM 1.5. Will you please tell me how to install first OpenFOAM 1.5 and then to OpenFOAM 1.5-dev.
Thanks in advance
Best Regards
Mubeen K Kurne
Old   February 24, 2011, 07:00
Robert
Hello Kurne, there is no need to install 1.5 first.
Are you using Ubuntu 10.04? The very easy procedure I described above works without flaw for me, and I have done it several times on different computers. Otherwise, I am sad to say I cannot help. I am not much of a computer expert or anything, and began using openfoam not too long ago.
Old   February 24, 2011, 08:27
Kurne
Dear Lordvon
I have installed OpenFOAM 1.6 on my ubuntu 10.04 Lucid and after that I followed the instruction given by the link
http://openfoamwiki.net/index.php/Installation and installed OpenFOAM 1.5-dev too. But the problem is to run the case files.Will you please tell me how to run the case and from where i get the tutorials of GGI because my case is of turbomachinery.
Thanks in advance.
Best Regards
Mubeen K Kurne
Old   February 24, 2011, 13:24
Robert
Heres the necessary files to run a case, from my files; youll have to change the BCs etc. (plenty of resources for that on the forums). Youll need to make your own mesh ggi-ready by following these steps (Post #3): http://www.cfd-online.com/Forums/ope...mixer-ggi.html.
Old   February 25, 2011, 00:55
Kurne
Dear Lordvon
Thanks for reply and posting the case file.Want to ask you one thing that you are running openFOAM 1.5-dev prior to installing it which version of openFOAM you have installed or directly you have install OpenFOAM 1.5-dev and run the case.
I mean that openFOAM 1.5-dev is directly start working without any openFOAM version installation.
Best Regards
Mubeen K Kurne
Old   February 25, 2011, 06:57
Robert
You do not need to do anything prior to the installation procedure for 1.5-dev I mentioned; with a fresh ubuntu installation, if you follow the aforementioned installation procedure, you will be ready to run the case immediately (once you have created your own mesh, etc. I deleted the mesh that was with that case file I posted up, so it has no mesh and wont run on its own, but if you follow the mesh generation procedure I linked to in my previous post you can generate one of your own).
Oh, and also I forgot to mention I am only familiar with 2D meshes, but I am sure going to 3D will not be too difficult.
Old   February 26, 2011, 19:59
Hrvoje Jasak
Just for the info: we also have 1.6-ext with further development of the GGI and other turbomachinery-related tools + the new version is in preparation. Please check
http://www.extend-project.de
for details.
Hrv
Hrvoje Jasak
Old   March 2, 2011, 02:01
Kurne
Dear Lordvon
Thanks A Lot for giving me guidance and i have successfully installed the OpenFOAM 1.5-Dev and its working too.Thanks Once Again.
Dear Hrv
Thanks a lot for help.I know it and studying too.Well I am happy that you have replied to me.Thanks.
Best Regards
Mubeen K Kurne
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
