January 27, 2011, 03:33 |
__Backward Facing Step simulation problems__
Dear Foamers,
I have simulated backward facing step with LES model. i created geometry with 200,000 grid. it is 3D with cyclic B.C for front and back walls. inlet conditions (U and k) are set same as Driver & Seegmiller paper. outlet pressure is set zero. I don't understand why: 1- Minimum pressure is -278 m2/s2. as you know it means -278000Pa. it is -2.78 Bar but it is not real to have less than -1 Bar. 2- Reattachment point should be near x=6H which H is step height. but it is more than 11 H in this simulation. what is the problem? Attachments are P and U contours. Thanks in advance, |
February 11, 2011, 16:20 |
inlet velocity turbulence was 0% in above snapshots. i changed it to 10%. So reattachment point becomes 8.5H instead of before 11H. H is step height. In Driver & Seegmiller reattachment should be 6H. i used LRR.
Changing inlet turbulent doesn't lead to desired one. What should be changed? Any help will be appreciated. |
Backward facing step. | Fluids | Main CFD Forum | 7 | December 4, 2012 12:28 |
Backward Facing Step with Blowing | azar | Main CFD Forum | 1 | November 16, 2006 02:01 |
Backward FAcing Step - Frequency | CFDtoy | Main CFD Forum | 8 | October 29, 2006 21:51 |
Reg: Supersonic flow past backward facing step | kiran | Main CFD Forum | 0 | September 30, 2006 06:07 |
Frontward facing step? | Anders Jönson | Main CFD Forum | 1 | March 26, 2002 21:39 |
