January 26, 2011, 10:21 |
parallel run for conjugateHeatFoam
Elisabet Mas de les Valls
Rep Power: 17 |
Dear all,
I wish to run a parallel case with conjugateHeatFoam (OF-1.5-dev), but neither 'decomposePar' nor a manually decomposition works. Does anyone have some experience or suggestions on it? I would really appreciate some help.... Elisabet |
January 26, 2011, 13:02 |
Nakul
Rep Power: 16 |
Please elaborate exactly what problems are you facing? Have you made the file decomposeparDict? What error message do you get on running decomposePar? |
January 26, 2011, 19:07 |
Rep Power: 17 |
Ok, I've taken a very simple case of a square channel aligned with x axis and two solid walls (at y+ and y- locations). Fluid domain is defined at the main folder and corresponds to region0, while solid domain is linked and located at '0', 'constant' and 'system' folders under the name 'solid', as defined in the tutorial example.
The case runs perfectly without parallelisation. In order to run the case in parallel, I first tried with the definition of the decomposeParDict at the main 'system' folder and run 'decomposePar', following the classical procedure in other solvers. However, an error was found. The output is rewritten here: Code:
Create time Time = 0 Create mesh for region region0 Calculating distribution of cells Selecting decompositionMethod simple Finished decomposition in 0.02 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Calculating processor boundary addressing Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 10080 Number of faces shared with processor 1 = 672 Number of processor patches = 1 Number of processor faces = 672 Number of boundary faces = 2232 Processor 1 Number of cells = 10080 Number of faces shared with processor 0 = 672 Number of processor patches = 1 Number of processor faces = 672 Number of boundary faces = 2232 Number of processor faces = 672 Max number of processor patches = 1 Max number of faces between processors = 672 Processor 0: field transfer request for polyMesh solid from objectRegistry conjugateHeat_parallel failed available objects of type polyMesh are 1 ( region0 ) From function objectRegistry::lookupObject<Type>(const word&) const in file lnInclude/objectRegistryTemplates.C at line 142. FOAM aborting Aborted elisabet |
January 26, 2011, 19:13 |
Rep Power: 17 |
Oh, by the way, I decompose the domain in 2 subdomains along x axis.
January 27, 2011, 02:28 |
Nakul
Rep Power: 16 |
Hi
By reading this message "request for polyMesh solid from objectRegistry conjugateHeat_parallel failed available objects of type polyMesh are" it seems to me that decomposePar is unable to split your solid region over two processors. As it can work only with mesh your solid region is coming in way. I have never tried parallelisation of regions with solid boundary before and this is what I have understood based upon my understanding of decompoPar. Try searching this forum for ways to split meshes with solid regions or try splitting your mesh in such a way that solid region doesn't get split. |
January 27, 2011, 05:53 |
Rep Power: 17 |
I've tried both things, without success.... that's why I decided to start a new threat.
When I split the domain avoiding to interact with the solid subdomain, 'decomposePar' provides the same error as before. Any idea? elisabet |
January 27, 2011, 16:54 |
it is possible but a lot of handish work
Jens Klostermann
Rep Power: 17 |
According to this thread http://hi.baidu.com/awacsljt/blog/it...4e6113aaf.html it is possible. And I just tried it myself and it works. Make also sure to use the harmonic scheme for the laplacian on the fluid side as mentioned in this thread: http://www.cfd-online.com/Forums/ope...penfoam-8.html Otherwise there also exist explicit coupling through the boundary chtXXXXMultiRegionFoam. Jens |
January 28, 2011, 10:32 |
#8 | |
Rep Power: 17 |
Hi Jens,
First of all thank you for the hints. I finally sorted out how to deal with parallel runs: it was so obvious.... but I didn't thought on it.... one just need to use the -region option with decomposePar !!!! So, the required steps are (within the structure of the conjugateHeatFoam tutorial case):
By the way: Quote:
Thanks! Elisabet |
January 31, 2011, 02:47 |
#9 | |
Jens Klostermann
Rep Power: 17 |
i don't get you question, but maybe this makes it clear: according to http://www.cfd-online.com/Forums/ope...penfoam-8.html you need to set the laplacian scheme in fvSchemes for the energy equation. Otherwise the temperature gradient at the coupled boundary will be wrong. laplacianSchemes { laplacian(DT,T) Gauss harmonic corrected; } Jens |
January 31, 2011, 07:46 |
#10 |
Rep Power: 17 |
Hi Jens,
Thanks for the answer. It's everything clear now. Sorry if I was not very explicit in my question. I call uncoupled variables those that need to be solved in a single domain (velocity and pressure) and coupled ones those that have to be solved with coupled domains (temperature for conjugateHeatFoam). Thank you very much!! elisabet |
February 4, 2011, 17:02 |
#11 |
Jens Klostermann
Rep Power: 17 |
Hi Elisabet,
Did you have luck with you parallel setup? The reason I am asking: -fluid (region0) decomposed and solid UNdecomposed runs fine with some speedup, -fluid (region0) decomposed and solid decomposed gives me an error as soon as the energy equation (T+T) gets solved. So I think it is because of the region coupling (e.g. attach detach)? But I don't know - maybe Hrv knows? Jens |
February 7, 2011, 10:00 |
#12 | ||
Rep Power: 17 |
Hi Jens,
I definitely had luck with my parallel simulation. At least, until now.... Quote:
I guess this is the unique (relevant) code modification I've done. Hope it helps! elisabet |
February 10, 2011, 10:54 |
#13 |
Jens Klostermann
Rep Power: 17 |
Since I use the OF-1.6.ext version the "bug" (which is http://www.cfd-online.com/Forums/ope...tml#post179753) was already gone. However I know where the code breaks right here:
// Add fluid equation TEqns.set ( 0, new fvScalarMatrix ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ) ); So I guess I need to digg further, maybe Hrv can push me further? Jens |
February 27, 2012, 22:09 |
#14 |
Rep Power: 16 |
Hi
I am trying to decompose the domain 2 rectangular domains, the first one is fluid an the second one is a rectangular solid domain immersed in the fluid, centered, this solid domain occupies 1/2 of the fluid domain in both directions, I decomposed the domain in the same number of processors, but unfortunately the boundaries do not match in the same the regionCoupling for solid and liquid do not match for some of the processors, Should I decompose both domains in different numbers of processors, in such a way that boundaries match? Any help is welcome, Thank you Alberto |
February 28, 2012, 06:42 |
decomposePar in parallel
#15 |
Rep Power: 17 |
Hi Alberto,
Since now, when I need to decompose a case with more than one domain, I must move to version 1.7.x to correctly decompose the case (with -region option, of course). Afterwards, I can return to my version (based on 1.6-ext) and run the case. I have experienced no problems with reconstruct tool. The error obtained when I decomposed the main case with OF-1.6-ext was something about a missing region, as far as I remember. I would appreciate to know other alternatives, if someone has experience on it!!! regards, elisabet |
May 22, 2012, 20:01 |
#16 |
Rep Power: 16 |
Hello Foamers
I am trying to use decomposePar for the geometry sketched below, fluid domain with a solid domain which length is a third of the liquid length, until now I can only run conjugateHeatFoam solver using 2 processor for the liquid and 2 for the solid (x-direction), is there a way to use at least 6 for the liquid and 2 for the solid, I have found the instruction globalFaceZones ( nameofzone1 nameofzone2 ); but I do not know how it works or if it is useful for my problem, Please let me know your opinion about this problem Any help is welcome. Thanks in advance. Alberto |
November 27, 2014, 23:37 |
the step 7 is wrong!
#17 | |
liuke
Rep Power: 13 |
conjugateheatfoam, parallel |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 15:43 |
Unable to run OF in parallel on a multiple-node cluster | quartzian | OpenFOAM | 3 | November 24, 2009 14:37 |
serial run fine, but parallel run diverged | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2009 09:33 |
Parallel run diverges, serial does not | SammyB | OpenFOAM Running, Solving & CFD | 1 | May 10, 2009 04:28 |
Run in parallel a 2mesh case | cosimobianchini | OpenFOAM Running, Solving & CFD | 2 | January 11, 2007 07:33 |
