time step in interFoam
Old   January 26, 2011, 09:22
Default time step in interFoam
Nima Samkhaniani
nimasam is on a distinguished road
hi dear foamer
i simulated stephan problem ( phase Change ) with open Foam a modified version of interFoam, now im going to compare the result with analytical solution, unfortunately time is making me messed up! what is the time ? it seems stupid but the question is?
1) is this time real time ( physical time on second ) ?
2) if yes, so could some one tell me whats the difference between timeStep,adjustableRunTime and runTime
P.S :
im using an implicit method to solve alpha1 equation in interFoam.
nimasam is offline   Reply With Quote
Old   January 26, 2011, 12:37
Wink Hope these are helpful
Charlie
cheng1988sjtu is on a distinguished road
timeStep:write data every N time steps, where N is defined in writeInterval;
runTime: write data every t seconds, t is the simulated time which is defined in writeInterval;
adjustableRunTime:
write data every t seconds, used in cases with automatic time step adjustment, it will change the time step to conincide with the writeInterval;
Basically, the three methods mentioned above are simulated flow time.
In caomparison, cpuTime and clockTime is not flowtime, it's either related to the time in windows clock, or in CPU time.
If I'm wrong, please let me~
cheng1988sjtu is offline   Reply With Quote
adjustableruntime, interfoam, runtime, time step
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 23:05
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 11:41
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 23:50
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Overflow problem in steady simulation ReeKo CFX 11 October 8, 2008 18:57
