Difference between 'internalField' and 'boundaryField'?
Like Tree35Likes
Old   May 5, 2014, 00:36
CHARLES
CHARLES is on a distinguished road
Thank you very much Armin! You solved my problem!
CHARLES is offline   Reply With Quote
Old   September 20, 2016, 07:29
Default Accessing nu and nut vales
  #22
Suman Chakraborty
suman91 is on a distinguished road
Hi there,
I am currently running a flow over backward facing step (using LES) in OpenFAOM 2.4.0. I want access to the kinematic viscosity. So in a ".H" file which I include in pisoFoam.C, I write the following just to see if I have access to nu (kinematic viscosity) value:
double k_viscosity;
const scalarField& nuCells = nu().internalField();
forAll(mesh.cells(), celli)
    k_viscosity = nuCells[celli];;
    Info<< "nu = " << k_viscosity << endl;
But during copiling i get error: "error: ‘nu’ was not declared in this scope"
I also want to access the nut values calculated by openFoam. Is there a function to access it ?
Thanks in advance.
suman91 is offline   Reply With Quote
boundaryfield, internalfield
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
boundaryField vs. internalField sebonator OpenFOAM 10 January 24, 2011 17:43
solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam maddalena OpenFOAM Running, Solving & CFD 43 January 11, 2011 03:39
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 07:22
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 05:53
