Experiences with OpenFOAM and Automobile External Aero
Old   January 21, 2011, 13:15
Default Experiences with OpenFOAM and Automobile External Aero
kyle is on a distinguished road
Would anyone be willing to share their experiences using OpenFOAM for automobile aero or underhood simulations? I have been evaluating this software for the better part of two months trying to get a feel for if we can replace Star-CCM+. Everything works great on our validation cases, but more complex geometry is troublesome. SnappyHexMesh is working for me very well. The mesh is at least as good at what I can get out of CCM+ and can be generated an order of magnitude faster. I can get very good results with simpleFoam and kOmega SST, but my main gripe is that I end up babysitting every run to convergence. I have to fiddle with solver settings and monitor max values for U/p/k and remove cells as they get out of control before they pollute the entire simulation. Any fvSolution/fvSchemes combination I get to work with one mesh seems to immediately diverge on the next mesh, no matter how similar the mesh.
I have spoken with engineers at other companies that have very robust OpenFOAM setups, but of course they were unable to give me any detailed information on how they got to that point. I am hoping someone here is able to share a little more. I'd love to hear about different workflows that are being used successfully and if possible even see some fvScheme/fvSolution/snappyHexMeshDict/other files that are being used in the wild. Failing that just let me know whether or not I have unrealistic expectations of this software!
Thanks for any information you can provide!
kyle is offline   Reply With Quote
Old   January 25, 2011, 08:30
Ralph Moolenaar
Ralph M is on a distinguished road
Hello Kyle,
Since a few weeks I've doing some aero calculations for a car (corvette C6). I'm using simplefoam with a mesh from SHM. Still in the phase of semi-2D but planning to go 3D next week. I'm willing to share the input files; I'll try to put them on this forum tonight.
Right now I'm exploring the possibilities for the 3D calculation; would it be possible to model the grill as a semi porous surface for example?
Cheers,
Ralph
CFD for marine applications? Go to http://www.marinecfd.com/ and join the OF Ship Hydromechanics Group: http://www.cfd-online.com/Forums/gro...mechanics.html
Ralph M is offline   Reply With Quote
Old   January 25, 2011, 12:55
Ralph,
Thanks for your reply. I have not gotten to this point yet, but I was planning on using a thin porous volume for the grill. This is my usual approach because unstructured mesh generators are usually not very well suited for creating a zero thickness wall within one volume. Anyway, I don't believe the OpenFOAM solver itself has support for porous walls without some sort of kludge using a cyclic boundary.
Kyle
Old   January 27, 2011, 12:26
Default snappyHexMesh prism layer problem
Daniel Peralta
leinadpm is on a distinguished road
I'm using snappyHexMesh (sHM) to generate the grid around a formula car wing, I tried a lot ways to make sHM to produce a continuous prims layer but I could not. So if anyone knows which of the sHM dictionary parameters can be modified to achieve that I'll be very grateful.
Thanks
http://i1220.photobucket.com/albums/.../ZoomLayer.jpg
http://i1220.photobucket.com/albums/...m/WingMesh.jpg
leinadpm is offline   Reply With Quote
Old   May 31, 2013, 22:40
jbr
jonbonraki is on a distinguished road
Originally Posted by Ralph M View Post
Hello Kyle,
Cheers,
Ralph
hi ralph i m doing an aero calucaltions for my project to reduce drag in suv, ur inputs file will be much appreciated, if your willing to share it would be really great raj123om@gmail.com
jonbonraki is offline   Reply With Quote
Old   October 24, 2013, 07:52
Default car OPENfoam
Tushar
patiltushar123 is on a distinguished road
hello,
u can create bl around any surface in shm, use one of foll:
> try and create bl's less than 7( this is weird, but true)
> try and use foam 2.2.x
With this two, i m sure it will work!
Also, u can try changing the face angle (default 150 deg)
patiltushar123 is offline   Reply With Quote
Automobile aero ground boundary layer OR simpleFoam/GAMG and high aspect ratio cells kyle OpenFOAM Running, Solving & CFD 4 January 4, 2011 12:17
