engrid: Internal volume mesh becoming coarser during boundayr layer addition
Old   January 21, 2011, 11:35
Default engrid: Internal volume mesh becoming coarser during boundayr layer addition
Arne Stahlmann
Arnoldinho is on a distinguished road
maybe it's a stupid question, but I have a problem using engrid for the boundary layer generation in 3D cases. (Sorry for posting the question here, but the engrid forum seems to be down). The orginally created internal (volume) mesh becomes coarser during the boundary layer or generally the volume mesh creation in engrid.
Let's explain the procedure: I have a block of lets say 1x1x1m that is horizontally divided into several (volume) layers. The layers have different resolutions/edge lengths of tet elements. The mesh is created in Salome using the Netgen algorithm; boundary patches have been created and the mesh is exported into .unv format. After conversion with ideasUnvToFoam, the mesh is imported into engrid by Import -> OpenFOAM case. Then I do "edit boundary conditions", create a new volume and set all boundary patches (six, from the cube sides) to green. Then I do "create prismatic boundary layer", pick the boundary condition to refine and set the conditions. The boundary layer is calculated/created as intended. Then I export the new mesh via Export -> OpenFOAM case (grid only).
No I come to the problem: When I open the mesh in Paraview, the surface mesh of the cube edges (outer 2D mesh) is still fine, but the internal (3D) volume mesh of the cube has become very coarse. No different resolutions of the volume layers can be found any more. So, where can I tell engrid to keep the former internal volume mesh resolutions?
Best regards,
Arne
Arnoldinho is offline   Reply With Quote
Old   January 22, 2011, 05:31
Arne Stahlmann
Ok, as the engits forum server is working again, the discussion about the topic can be found here http://engits.eu/vanilla/index.php?p...er-creation/p1 ... just for the case someone has the same problem.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 03:22
Interpolating volume data onto quad surface mesh N.R. CFX 6 June 7, 2007 09:15
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
