how to calculate the pressure coefficient of a wing |
January 20, 2011, 10:33 |
chenkai
Rep Power: 16 |
Hi FoamUsers,
I want to simulate the ONERA M6 Wing. But do not know how to calculate the pressure coefficient for the upper and lower surface of the airfoil. Does anyone has idea how to realize it? Thanks a lot in advance! |
January 21, 2011, 09:59 |
Nakul
Rep Power: 16 |
As far as I know there is now tool at present that lets you calculate Cp in OF. (But if you come across one, do post it here.) However you can add code to calculate Cp in your solver using "Function Objects". Just search this on google and you would get all the details. Moreover you can simply write those lines in your solver and recompile it. |
January 27, 2011, 15:38 |
Hi foamers,
DO you know how to creat an 1D data file by intersecting a plane in the boddy or wing? Regards |
How to calculate mean pressure | kmgraju | CFX | 2 | August 1, 2010 13:55 |
How to calculate Volumetric Mass transfer coefficient using CFX? | tuks_123 | CFX | 2 | July 22, 2010 01:15 |
how does Fluent calculate the pressure and viscous force vector? | Ralf Schmidt | FLUENT | 2 | May 17, 2010 15:49 |
XY plotting pressure coefficient on the wall | Yucel Ozmen | FLUENT | 2 | January 16, 2006 21:36 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 04:15 |
