about chemkintofoam
Like Tree2Likes
Old   May 15, 2011, 12:26
Default Using GRIMech3(chemkin format) in OpenFoam
  #21
Ali Shamooni
Alish1984 is on a distinguished road
Hi
The GRIMech3 "CHEMKINFile" and "CHEMKINThermoFile" are adapted to use in openfoam
New files which can be used in OF are:GRI3.inp and thermGRI3.dat
Old files(the source files from http://www.me.berkeley.edu/gri_mech/ ) are:GRI3.old.inp and thermGRI3.old.dat
Changes:
1.CH2(S) to CH2S in both CHEMKINFile and CHEMKINThermoFile
2.THERMO to THERMO ALL in CHEMKINThermoFile
3.all the 300.000 temperatures to 298.150 temperatures inCHEMKINThermoFile
Regards
Jacob and justsmile2007 like this.
Alish1984 is offline   Reply With Quote
Old   May 15, 2011, 12:35
dahlia-2005 is on a distinguished road
Ali, great!
You did pretty well!
dahlia-2005 is offline   Reply With Quote
Old   March 25, 2015, 12:32
Default GRIMech how to translate to CHEMKIN format?
  #23
Howar
Howard is on a distinguished road
Originally Posted by Alish1984 View Post
Hi
Changes:
Regards
Hi,friend. Now I try to use some other multistep mechanism but the problem is from some websites like the attachment, which is GRIMech, do you know how to translate to CHEMKIN format? or use it in openfoam
Howard is offline   Reply With Quote
Old   March 25, 2015, 12:37
Howar
Originally Posted by dahlia-2005 View Post
I am trying to import GRImech3.0 to reactingFoam, and I use the chemkintoFoam utility. The thermo30.dat can be changed to thermo.compressibleGas(When I added "All" in the back of "THERMO" in the thermo30.dat ) successfully.
but the simulated highest temperature is so low (<1500K ). I do not konw the reason, and I can not find the solution from CFD-online-openfoam.
Anyone can help me? thank you in advance.
Hi,friend. I found some mechanism like attachment, GRIMech, do you know how to make CHEMKIN format like .inp .dat?
Sorry I mistakenly ask in the same post, but I still don't know the answer.
Old   February 19, 2017, 04:10
Thalhah
thalhah90 is on a distinguished road
Dear dahila
I used DRM22 http://www.me.berkeley.edu/drm/ -which is a reduced version of GRI mech 1.2 with 22 species- for methane combustion with OF171 and OF15dev successfully but DRM22 does not have NOX and i decided to use GRI mech 3 and it was the time my problems start
if u don’t want to analyze Nox formation I advise u to use this mechanism.
I dont want to use nor cantera neither chemkin,I must use OF171 or OF15dev in my project and the problems always occur when there is some MUST or MUST not.....
OpenFOAM newbie here. I am currently learning to use reactingFoam solver, OpenFOAM version 3.0.1. Can I use GRI-Mech of methane combustion for a burner with mixed fuel (methane-ethylene) composition? The volume percent of the fuel under study is 30%CH4 & 5%C2H4. Should I use mechanism for methane combustion or for ethylene combustion? Or just one type of mechanism? Any help is greatly appreciated.
Thank you
thalhah90 is offline   Reply With Quote
Chemkin reader stefanke OpenFOAM Pre-Processing 28 March 8, 2022 11:16
