January 13, 2011, 10:33 |
Meshing problem
Andrea Ferrari
Rep Power: 17 |
Hi all,
I am trying to build a structured mesh around some discs (2D problem) using gmsh for construct the geometry and the mesh. Here my .geo file. // Gmsh project created on Tue Jan 11 13:20:10 2011 lc=0.001; dx=0.001; dy=0.001; c1x=0.0005; c1y=0.0005; r1=0.0002; c2x=0.0004; c2y=0.0015; r2=0.00025; c3x=0.0016; c3y=0.0014; r3=0.0003; c4x=0.0013; c4y=0.0002; r4=0.0001; Function CheeseHole lc=0.001; p1 = newp; Point(p1)={x,y,z,lc}; p2 = newp; Point(p2)={x+r,y,z,lc}; p3 = newp; Point(p3)={x-r,y,z,lc}; p4 = newp; Point(p4)={x,y+r,z,lc}; p5 = newp; Point(p5)={x,y-r,z,lc}; p6 = newp; Point(p6)={dx1,y,z,lc}; p7 = newp; Point(p7)={dx2,y,z,lc}; p8 = newp; Point(p8)={x,dy1,z,lc}; p9 = newp; Point(p9)={x,dy2,z,lc}; p10 = newp; Point(p10)={dx1,dy1,z,lc}; p11 = newp; Point(p11)={dx1,dy2,z,lc}; p12 = newp; Point(p12)={dx2,dy1,z,lc}; p13 = newp; Point(p13)={dx2,dy2,z,lc}; c1 = newreg; Circle(c1) = {p2,p1,p4}; c2 = newreg; Circle(c2) = {p3,p1,p4}; c3 = newreg; Circle(c3) = {p3,p1,p5}; c4 = newreg; Circle(c4) = {p2,p1,p5}; l1 = newl; Line(l1) = {p13,p7}; l2 = newl; Line(l2) = {p7,p2}; l3 = newl; Line(l3) = {p4,p9}; l4 = newl; Line(l4) = {p9,p13}; l5 = newl; Line(l5) = {p9,p11}; l6 = newl; Line(l6) = {p11,p6}; l7 = newl; Line(l7) = {p6,p3}; l8 = newl; Line(l8) = {p10,p6}; l9 = newl; Line(l9) = {p8,p10}; l10 = newl; Line(l10) = {p5,p8}; l11 = newl; Line(l11) = {p8,p12}; l12 = newl; Line(l12) = {p12,p7}; lp1 = newreg; Line Loop(lp1) = {l1,l4,l3,c1,l2}; Plane Surface(newreg) = {lp1}; lp2 = newreg; Line Loop(lp2) = {l3,l5,l6,c2,l7}; Plane Surface(newreg) = {lp2}; lp3 = newreg; Line Loop(lp3) = {l7,l8,l9,c3,l10}; Plane Surface(newreg) = {lp3}; lp4 = newreg; Line Loop(lp4) = {l10,l11,l12,c4,l2}; Plane Surface(newreg) = {lp4}; Transfinite Line {l1} = n1; Transfinite Line {l2} = n2; Transfinite Line {l3} = n2; Transfinite Line {l4} = n4; Transfinite Line {l5} = 42-n4; Transfinite Line {l6} = n1; Transfinite Line {l7} = n2; Transfinite Line {l8} = 42-n1; Transfinite Line {l9} = 42-n4; Transfinite Line {l10} = n2; Transfinite Line {l11} = n4; Transfinite Line {l12} = 42-n1; Transfinite Line {c1} = n1+n4-1; Transfinite Line {c2} = 42-n4+n1-1; Transfinite Line {c3} = 84-n1-n4-1; Transfinite Line {c4} = 42-n1+n4-1; Transfinite Surface {lp1+1} = {p9,p4,p2,p7}; Transfinite Surface {lp2+1} = {p9,p4,p3,p6}; Transfinite Surface {lp3+1} = {p6,p3,p5,p8}; Transfinite Surface {lp4+1} = {p7,p2,p5,p8}; Recombine Surface {lp1+1,lp2+1,lp3+1,lp4+1}; Extrude {0, 0, 0.00001} { Surface{lp1+1,lp2+1,lp3+1,lp4+1}; Layers{1}; Recombine; } Return n2=30; //internal point //n1 : point on boundary y direction //n4 : point on boundary x direction x=c1x; y=c1y; z=0; r=r1; dx1=0; dx2=0.001; dy1=0; dy2=0.001; n1=21; n4=21; Call CheeseHole ; x=c2x; y=c2y; z=0; r=r2; dx1=0; dx2=dx; dy1=dy; dy2=2*dy; n1=21; n4=25; Call CheeseHole ; x=c3x; y=c3y; z=0; r=r3; dx1=dx; dx2=2*dx; dy1=dy; dy2=2*dy; n1=25; n4=17; Call CheeseHole ; x=c4x; y=c4y; z=0; r=r4; dx1=dx; dx2=2*dx; dy1=0; dy2=dy; n1=33; n4=29; Call CheeseHole ; Physical Surface("frontback") = {166, 333, 255, 368, 65, 232, 50, 251, 364, 461, 383, 446, 34, 465, 123, 500, 152, 210, 150, 183, 156, 264, 237, 154, 342, 284, 315, 282, 288, 396, 369, 286, 414, 447, 474, 416, 51, 18, 78, 20, 105, 22, 132, 24, 501, 418, 528, 420}; Physical Surface("top") = {197, 182, 329, 314}; Physical Surface("bottom") = {515, 496, 119, 100}; Physical Surface("left") = {201, 236, 69, 104}; Physical Surface("right") = {298, 387, 430, 519}; Physical Surface("obstacle") = {174, 209, 224, 263, 77, 42, 131, 92, 306, 341, 356, 395, 473, 438, 527, 488}; Physical Volume("internal") = {6, 5, 8, 7, 2, 1, 10, 11, 12, 9, 13, 14, 15, 16, 4, 3}; Are four circles surrounded by four squares (is the only way I found to keep the grid structured). In the "frontback" patch there are also the internal surface that separate the 4 squares because otherwise openfoam adds these automatically to the "DefaultFaces" (..with other error). Seems that open foam has a problem on the internal surfaces that separate a square and the other or maybe i defined a wrong geometry. when i check the mesh with the checkMesh utility i found: Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 38386 internal points: 0 faces: 74880 internal faces: 36480 cells: 18560 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 18560 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 4 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology frontback 37440 38386 multiply connected (shared edge) obstacle 640 1280 ok (non-closed singly connected) left 80 162 ok (non-closed singly connected) bottom 80 162 ok (non-closed singly connected) top 80 162 ok (non-closed singly connected) right 80 162 ok (non-closed singly connected) defaultFaces 0 0 ok (empty) <<Writing 2 conflicting points to set nonManifoldPoints Checking geometry... Overall domain bounding box (0 0 0) (0.002 0.002 1e-05) Mesh (non-empty, non-wedge) directions (0 0 0) Mesh (non-empty) directions (0 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 73294 <<Writing 38352 points on non-aligned edges to set nonAlignedEdges Boundary openness (-1.0427e-19 -2.39822e-18 -1.77514e-19) OK. Max cell openness = 3.24449e-16 OK. Max aspect ratio = 8.43589 OK. Minumum face area = 1.62992e-11. Maximum face area = 6.1562e-10. Face area magnitudes OK. Min volume = 1.62992e-16. Max volume = 6.1562e-15. Total volume = 3.364e-11. Cell volumes OK. Mesh non-orthogonality Max: 74.3236 average: 27.2494 *Number of severely non-orthogonal faces: 159. Non-orthogonality check OK. <<Writing 159 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.59138 OK. Failed 1 mesh checks. End I guess that the error is on the internal faces. For the centers of the discs I used only discrete positions to ensure that the mesh matches itself on the edge. Could it be that the interior lines and points are defined twice (once for each square)?? I have attached my geometry and my .geo (txt) file. Thanks Andrea |
January 13, 2011, 10:36 |
Andrea Ferrari
Rep Power: 17 |
This is the error if i launch the simulation using interFoam:
FOAM FATAL ERROR: [3] This mesh contains patches of type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells. [3] [3] From function emptyFvPatchField<Type>::updateCoeffs() [3] in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 150. |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 08:21 |
Gambit meshing problem | nana | ANSYS Meshing & Geometry | 5 | August 31, 2009 06:58 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 21, 2006 00:31 |
Problem meshing very thin pipe | B. Hemmen | FLUENT | 2 | May 16, 2006 09:29 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 10:22 |
