OpenFoam error
Old   January 10, 2011, 05:21
Unhappy OpenFoam error
Arsinoe
Arsinoe is on a distinguished road
I'm new with linux and as I run my XiFoam script, this type of error appears :
#0 Foam::error:rintStack(Foam::Ostream&) in "/nfs/public/SI/Cardenas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/nfs/public/SI/Cardenas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 main in "/nfs/public/SI/Cardenas/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/XiFoam"
#4 __libc_start_main in "/lib64/libc.so.6"
#5 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
what does that mean?
thanks for your help!
Arsinoe is offline   Reply With Quote
Old   January 10, 2011, 06:11
Nakul
nakul is on a distinguished road
Are you running this script on your own case?
If yes then there is some problem with your initial conditions or BC. Check them again.
Otherwise provide more details about your test case setup.
nakul is offline   Reply With Quote
Old   January 11, 2011, 09:19
Arsinoe
ok I think the problem may come from the ignition site :
ignitionSites ( { location ( 0 0.005 0.01 ) ; diameter 0.0001 ; start 0 ; duration 0.0001 ; strength 1 ; } ); // ignition time and location
ignitionSphereFraction 1; //ignition is plane
ignitionThickness ignitionThickness [ 0 1 0 0 0 0 0 ] 0.0001;
ignitionCircleFraction 0.5;
ignitionKernelArea ignitionKernelArea [ 0 2 0 0 0 0 0 ] 0.002;
Does someone know what that means and how we use it ?
Thanks
Old   June 6, 2011, 22:56
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Thanks
I am also working with this solver, I change the geometry of the pitzDaily tutorial and include more ignition sites, I could to run the tutorial with a new geometry (with meshes from Gmsh) and new inlets, and now I can to define new ignition points to continue doing test, but so far I cannot doing that . I think that if you did not change the files of the tutorial case, this should run well. If you are working with combustion processes like me, I think that we can exchange experiences my email is lfgmarcantoni@gmail.com.
Best regards
Felipe
lfgmarc is offline   Reply With Quote
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 10:27
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
user defined function cfduser CFX 0 April 29, 2006 11:58
