reactingFoam: ODE Solver KRR4 "Too many integration steps" |
January 6, 2011, 05:27 |
Paul
Rep Power: 17 |
Hello all,
I've been trying to do some simulations with reactingFoam. I've also used different ODE Solver (SIBS, RK, KRR4) to see if it's possible to get a stable simulation. Both Solver (RK, KRR4) stops with following error message: Code:
Courant Number mean: 0.0104708 max: 0.394021 deltaT = 3.1361e-05 Time = 0.00293728 Solving chemistry --> FOAM FATAL ERROR: Too many integration steps From function ODESolver::solve(const ODE& ode, const scalar xStart, const scalar xEnd,scalarField& yStart, const scalar eps, scalar& hEst) const in file ODESolvers/ODESolver/ODESolver.C at line 107. FOAM exiting The SIBS Solver stops with following error message: Code:
Solving chemistry --> FOAM FATAL ERROR: attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 187.14 From function janafThermo<equationOfState>::checkT(const scalar T) const in file /home/opencfd/OpenFOAM/OpenFOAM-1.7.x/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 63. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> >::H(double) const in "/opt/openfoam171/lib/linuxGccDPOpt/libreactionThermophysicalModels.so" #3 Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > >::solve(double, double) in "/opt/openfoam171/lib/linuxGccDPOpt/libchemistryModel.so" #4 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/reactingFoam" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/reactingFoam" Aborted Thanks in advance. pajofego *********************************chemestryProperti es********************************** /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class dictionary; location "constant"; object chemistryProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // psiChemistryModel ODEChemistryModel<gasThermoPhysics>; chemistry on; chemistrySolver ode; //chemistrySolver EulerImplicit; //chemistrySolver sequential; initialChemicalTimeStep 1e-07; turbulentReaction on; sequentialCoeffs { cTauChem 0.001; equilibriumRateLimiter off; } EulerImplicitCoeffs { cTauChem 0.05; equilibriumRateLimiter off; } odeCoeffs { ODESolver KRR4; //RK; //KRR4; eps 0.05; scale 1; } Cmix Cmix [ 0 0 0 0 0 0 0 ] 0.1; // ************************************************** *********************** // |
January 7, 2011, 06:24 |
Nakul
Rep Power: 16 |
These error are coming because your solution begins to diverge. I don't think its a good idea to change the maximum number of integration steps without properly understanding its theoretical background. Rather its better if you make changes in your test case and try to run it completely with SIBS and then see if you still get any error with KRR4. You may check your BC as they are a major reason for causing the JANAF error you are getting with SIBS. |
February 18, 2013, 21:40 |
Rep Power: 14 |
Hi Nakul, I also meet the "too many integration step" problem, can you specify the possibility of the BC or is there any previous post discussing this?
Thanks |
May 18, 2013, 15:15 |
Rep Power: 14 |
Hi,pajofego
I confront this problem too, did you find the reason eventually? Thanks |
ODE solver coefficients | mrangitschdowcom | OpenFOAM Running, Solving & CFD | 2 | August 18, 2013 22:16 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
ODE solver extension to RKtime integration for CFD | luca_g | OpenFOAM Running, Solving & CFD | 4 | September 26, 2007 06:44 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Need ODE solver | Levi | Main CFD Forum | 3 | April 9, 2003 22:38 |
