k-omega in wingmotion tutorial
Old   December 29, 2010, 08:33
Default k-omega in wingmotion tutorial
Jonas Lintermans
jlinterm is on a distinguished road
Dear CFD-community,
I would like to understand the following piece of code in the wingMotion-tutorial with pimpleDyMFoam-solver. In the 0/omega-file it states:
wing
        type            omegaWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E                 9.8;
        beta1           0.075;
        value           uniform 32;
How can I calculate these values separately? Wil a change in these values going to cause a drastic change in the result of the case?
Also, I'm trying to run the tutorial longer than 1 sec, now 3sec but OpenFOAM stops calculating after 2.79sec, finishing with an error: sigFpe and Foam::error:rintStack(Foam::Ostream&). Changing the tolerances a little bit in the fvSolution-file resulted in a extension of the calculation to 2.93sec. Any idea how to solve the case for 5sec without giving an error?
Greetings,
jlinterm is offline   Reply With Quote
Old   December 29, 2010, 16:34
Dave
daveatstyacht is on a distinguished road
Jonas,
Those with the exception of "values= 32", the values listed are intrinsic either to the turbulence model itself or to turbulence theory (kappa = 0.41). If you change these values you will likely get something unphysical. Also if you neglect to have those lines, OF will default to the default values for them (which off the top of my head those are the values). The "values= 32" refers to the value of omega based on your given flow condition and this is the only value you are likely to want to change if you are changing things like velocity, viscosity, etc. Hope that helps.
Dave
daveatstyacht is offline   Reply With Quote
k-omega, printstack, sigfpe, tutorial, wingmotion
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 12:42
[snappyHexMesh] wingMotion Tutorial dancfd OpenFOAM Meshing & Mesh Conversion 3 November 13, 2016 11:12
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 04:25
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 06:15
