Modifying Simple Buoyant Tutorial
Old   December 20, 2010, 04:29
Post Modifying Simple Buoyant Tutorial
cbritan is on a distinguished road
I am new to OpenFOAM and I am trying to make a very simple modification to the hotRoom tutorial in the buoyantSimpleFoam tutorial. I would simply like to add one patch with a temperature of 310K on the floor. Please see the attached image and code for the blockMeshDict. When I run blockMesh I get an error stating that face 0 in patch 0 does not have a neighbour cell face: 4(0 1 4 5). I'm guessing this should be a simple fix for someone experienced with OpenFOAM and I am lost for ideas. Thanks for your help.
-Clark
convertToMeters 1;
vertices
(0 0 0) //0
(5 0 0) //1
(10 0 0) //2
(10 0 10) //3
(5 0 10) //4
(0 0 10) //5
(0 5 0) //6
(10 5 0) //7
(10 5 10) //8
(0 5 10) //9
blocks
hex (0 2 3 5 6 7 8 9) (20 10 20) simpleGrading (1 2 1)
edges
patches
wall floor
(0 1 4 5)
wall ceiling
(6 7 8 9)
wall fixedWalls
(0 6 9 5)
(0 6 7 2)
(2 7 8 3)
(5 3 8 9)
patch hot
(1 2 3 4)
cbritan is offline   Reply With Quote
Old   December 21, 2010, 05:08
Default Resolved Issue, But Still Confused
I was able to solve the problem by splitting the region into two meshes as shown in the attached drawing. However, I still seem to be misunderstanding something fundamental with OpenFOAM. Why is it necessary to add the second mesh to solve this simple problem? I imagine there should be a way to create this model using only one mesh?
Thanks for the help.
-Clark
Old   December 21, 2010, 05:25
Bernhard
Bernhard is on a distinguished road
It is clear that it is not necessary to split your mesh indeed.
There are two alternatives:
1. You can define your temperature boundary condition in the 0/T file, using a list.
2. You can use groovyBC ( http://openfoamwiki.net/index.php/Contrib_groovyBC ), where setting these boundary conditions is a lot easier.
Bernhard is offline   Reply With Quote
Old   January 26, 2011, 01:03
Default Outlet Region of Patch
Thanks Bernhard.
I actually found the funkySetFields utility to be quite useful for this application. funkySetFields makes it very easy to set a different temperature, velocity, pressure, etc. to specific areas of a mesh or patch.
However, I am not able to create an outlet to a specific region of a patch without creating a separate mesh for the portion of the patch representing the outlet.
Any ideas?
hotroom, tutorial
Question from tutorial: Buoyant flow in a partitioned cavity noppawit CFX 13 March 19, 2014 03:18
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Tutorial 13 in version 3.26.004 - simple ICE Luke Siemens 4 May 18, 2008 15:30
[blockMesh] Tutorial for Creating Simple 3D Meshes jonlemur OpenFOAM Meshing & Mesh Conversion 4 August 8, 2007 14:20
