December 14, 2010, 13:20 |
Free surface problem: hull mesh questions
edoardo
Rep Power: 16 |
Hello!
I'm trying to evaluate the wave pattern generated by a sailing boat hull at Fr=0.35. After a quite long period studying an analogue problem with the wigley hull reported in this forum and after getting a little more experienced i would try with my model: it's a sailing boat of 12 meters. Let's start from the beginning: i'm trying to mesh it in a very similar way to that used for the wigley hull (posted in this forum) but as the geometry is a little more complicated i'm still working on it. I'm also trying to understand wich is a good preprocessing software to get the final mesh and boundary conditions for openfoam. As this is an initial study, hull appendages can be removed. As you can see i have a lot of work in front of me so any sugestion is welcome, thank you very much. I generated to hull geometry by myself and there is no commercial interest in this post. You can use theese files as you want...just let me know if you get the solution! http://dl.dropbox.com/u/14793999/hull.zip |
December 15, 2010, 03:50 |
Rep Power: 19 |
Hi Edoardo,
You are not the only one working on problems like this. I'm working on this for the last four month now, not only meshing, but also resistance calculations, generating of wave patterns and so on. As I can see from your zip file is that you have iges files already which is actually a good starting point, I use the same. For me the best suiting OpenSource software to get from these kind files to a proper mesh is using Salome and the OpenFoam included meshing tools blockMesh and snappyHexMesh. With Salome you create a solid of your geometry and store it as a hull.stl file. This you copy in your case directory in the constant/triSurface folder. Then you create a simple block or if you prefere a wedge background domain with all necessary BCs Once you have done that you include your stl file in the snappyHexMeshDict file and adjust your mesh to your needs. After that simply execute blockMesh snappyHexMesh -overwrite and you are done. But be carefull: snappyHexMesh is as hard to learn as OpenFoam and I highly recommend you the motorBike tutorial in the simpleFoam tutorials and to read the docmentation section in the user guide of OF. For my needs this system is sufficient, however I have no experience in using engrid or other meshing tools which might also be good to mesh a ship hull form. For more specific questions on salome and sHM you can use the specific forums in the OpenFoam meshing section. regards Colin |
December 15, 2010, 20:50 |
Vieri Abolaffio
Rep Power: 17 |
hi Alberto.
first of all good luck for your work. from what friends of mine have said doing those analysis with OF you'll need it. ^__^ on the other hand, i have a question for you. do you have any experimental data about this hull? i'm afraid i can't help you for the analysis setup, since i'm a true beginner of OF, but i'll try to mesh it for you using commercial software. just do not hold your breath, because it can take me some time. bye |
free surface, sailingboat, wigley |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
Problem with capturing water-spreading for free surface flow | devesh.baghel | OpenFOAM | 2 | December 10, 2009 02:21 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
