December 9, 2010, 18:17 |
Acoustic field in a centrifugal fan
Mohammad.R.Shetab
Rep Power: 16 |
Hi everyone
I want to work on the noise prediction of a centrifugal fan with radios about 30cm.(745 rpm) The question is because I should predict pressure fluctuations, should I solve the flow compressible or incompressible?!!! And what solvers should I use?!! thanks Mohammadreza |
December 10, 2010, 02:59 |
Tobias Holzinger
Rep Power: 17 |
Hi Mohammadreza,
sounds quite incompressible, so I would recommend icofoam. I only do compressible simulations with rhoPisoFoam... Depends on what you want to simulate... Maybe you should first define your goals before you select the solver...
Tobias Holzinger Chair of Thermodynamics, TU München |
December 10, 2010, 06:19 |
even for acoustic field?!
Mohammad.R.Shetab
Rep Power: 16 |
Dear Tobias
Thank you for your answer. I know that the flow is incompressible and it should be solved with solvers MRFSimpleFoam(for steady) and turbDyMFoam(for unsteady). But my question is acoustic field is something different from flow field. I mean noise generation and propagation is something based on pressure fluctuaion and relatively density fluctuation. In this kind of problems, should I still solve the flow incompressible?!! Thanks Mohammadreza |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Modeling of centrifugal fan in CFD | Simon Williams | Main CFD Forum | 3 | February 20, 2009 16:00 |
How to model flow of centrifugal fan? | Peter | Main CFD Forum | 0 | April 2, 2008 07:07 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
centrifugal pump and centrifugal fan | Mangesh | Main CFD Forum | 3 | January 3, 2006 12:21 |
