January 28, 2011, 12:58 |
#21 |
Martin
Rep Power: 22 |
Hi again,
I found the bug: a bracket related problem... so here comes the (hopefully) correct parallel version: Code:
#include "RASModel.H" // write matlab file { Info << "Writing Area of the cells on the patch!" << endl; word wallPatchName = "obstacle"; Info << "Searching for patch " << wallPatchName << endl; // Check, if the patch name exists: label patchID = mesh.boundaryMesh().findPatchID(wallPatchName); if (patchID < 0) { Info << "No patch found with name \"" << wallPatchName << "\"!" << endl; } // Pointer to the patch we want to have shear stress for: const polyPatch& cPatch = mesh.boundaryMesh()[patchID]; label nFaces = cPatch.size(); pointField faceAreas(nFaces, vector(0,0,0)); label runFaces = 0; // collecting the interesting data for (int i=0; i<nFaces; i++) { faceAreas[runFaces] = mesh.Sf().boundaryField()[patchID][i]; runFaces++; } // for parallel reduce(nFaces, sumOp<label>()); Info << "Number of global faces: " << nFaces << endl; // make a cute filename fileName casePath = cwd();//casePath.name(); fileName caseName = casePath.name(); fileName myFile = "area.dat"; Info << "Data is written to file " << myFile << endl; // create a new file OFstream *myStream = NULL; if (Pstream::master()) { myStream = new OFstream(myFile); } // slaves send data to master, master writes data to file if (Pstream::parRun()) { if (Pstream::myProcNo() != Pstream::masterNo()) { OPstream toMaster(Pstream::blocking, Pstream::masterNo()); toMaster << faceAreas; } else // master part { // first write own data for (int i=0; i<faceAreas.size(); i++) { *myStream << i << ";" << mag(faceAreas[i]) << endl; } label run = faceAreas.size(); // then receive slave data and write pointField bufferFaceAreas; for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++) { IPstream fromSlave(Pstream::blocking, slave); fromSlave >> bufferFaceAreas; for (int i=0; i<bufferFaceAreas.size(); i++) { *myStream << run << "; " << mag(bufferFaceAreas[i]) << endl; run++; } } } } else // single processor only { for (int i=0; i<nFaces; i++) { *myStream << i << "; " << mag(mesh.Sf().boundaryField()[patchID][i]) << endl; } } } Martin |
January 31, 2011, 06:21 |
#22 |
Andrea Ferrari
Rep Power: 17 |
Hi Martin,
after wclean and wmake i got this error (i dont know if the instructions that you had given to compile simpleFoam are the same for interFoam (the solver that i use) but seems that there is some error on #include RASModel.H) Making dependency list for source file interFoam.C could not open file RASModel.H for source file interFoam.C SOURCE=interFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/interfaceProperties/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/turbulenceModel -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/interFoam.o In file included from interFoam.C:125: write.H:1:22: error: RASModel.H: No such file or directory /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H: In function â: /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable â /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable â /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable â /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:8: warning: unused variable â /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable â /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable â make: *** [Make/linux64GccDPOpt/interFoam.o] Error 1 Thanks again Andrea |
January 31, 2011, 08:20 |
#23 |
Martin
Rep Power: 22 |
Hi Andrea,
just remove the line "#include RASModel.H". It was necessary for wall shear stress calculation in the original piece of code... Martin |
January 31, 2011, 09:55 |
#24 |
Andrea Ferrari
Rep Power: 17 |
I figured that was enough to remove that line. I just launched a test. I write to you in case there are errors. Thank you very much for all your help.
Andrea |
February 11, 2011, 06:19 |
#25 |
Andrea Ferrari
Rep Power: 17 |
Hi Martin, everything works fine!
I am taking advantage of your patience to ask another thing. I would like to calculate the gradient of alpha1 for each cell and each time step. I tried to write this piece of code: writeGradientAlpha1.C (writeCellVolumes.C them). Please look if is ok. I do not know if i have included the right source file (.H). I guess the function to calculate gradient is fvcGrad:field). Code:
#include "argList.H" #include "timeSelector.H" #include "Time.H" #include "fvMesh.H" #include "vectorIOField.H" #include "volFields.H" #include "fvcGrad.H" using namespace Foam; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Main program: int main(int argc, char *argv[]) { timeSelector::addOptions(); # include "setRootCase.H" # include "createTime.H" instantList timeDirs = timeSelector::select0(runTime, args); # include "createMesh.H" forAll(timeDirs, timeI) { runTime.setTime(timeDirs[timeI], timeI); Info<< "Time = " << runTime.timeName() << endl; // Check for new mesh mesh.readUpdate(); volVectorField gradAlpha1 ( IOobject ( "GradAlpha1", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), volVectorField gradAlpha1 = fvc::grad(alpha1) ); Info<< "Writing gradAlpha1 to " << gradAlpha1.name() << " in " << runTime.timeName() << endl; gradAlpha1.write(); } Info<< "\nEnd" << endl; return 0; } // ************************************************************************* // andrea |
February 11, 2011, 11:15 |
#26 |
Martin
Rep Power: 22 |
Hi Andrea,
you must read the alpha1 field from disk first, otherwise your tool doesn't know what to work on. Extract the attached tool to your user directory, for example .../OpenFOAM/andrea-1.7.1/ and call wmake in the new folder. Have fun Martin |
February 11, 2011, 11:22 |
#27 |
Andrea Ferrari
Rep Power: 17 |
can i put this code in the /home/../applications/utilities/postProcessing/miscellaneous/ like writeCellCenter? for the next help I guess I will have to pay!! Thanks andrea |
February 11, 2011, 11:26 |
#28 |
Martin
Rep Power: 22 |
Yes, you can.
Please have a look at the file Make/options Right now the executable is written to $(FOAM_USER_APPBIN) so only you have access to it. If you want to make it available globally (for other users), you may want to change this variable to $(FOAM_APPBIN) Martin |
February 11, 2011, 12:11 |
#29 |
Andrea Ferrari
Rep Power: 17 |
Yes, i know that.
Thanks a lot andrea |
February 14, 2011, 07:40 |
#30 |
Andrea Ferrari
Rep Power: 17 |
Hi Martin,
I have copied all file in the right directory and then wmake. When i call writeGradientAlpha1 from my case directory i got this error: | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-21131bcbd876 Exec : writeGradientAlpha1 Date : Feb 14 2011 Time : 12:28:14 Host : master.cluster PID : 25375 Case : /home/aferrari/Simulation/OstacoliRandom/simm2e-2alpha30/simmetricou2e-2 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Reading field alpha1 --> FOAM FATAL IO ERROR: Unknown patchField type constantAlphaContactAngle for patch type wall Valid patchField types are : 41 ( advective buoyantPressure calculated cyclic directMapped directionMixed empty fan fixedFluxPressure fixedGradient fixedInternalValue fixedPressureCompressibleDensity fixedValue freestream freestreamPressure inletOutlet inletOutletTotalTemperature mixed oscillatingFixedValue outletInlet partialSlip processor rotatingTotalPressure sliced slip symmetryPlane syringePressure timeVaryingMappedFixedValue timeVaryingMappedTotalPressure timeVaryingTotalPressure timeVaryingUniformFixedValue timeVaryingUniformInletOutlet totalPressure totalTemperature turbulentInlet turbulentIntensityKineticEnergyInlet uniformDensityHydrostaticPressure uniformFixedValue waveTransmissive wedge zeroGradient ) file: /home/aferrari/Simulation/OstacoliRandom/simm2e-2alpha30/simmetricou2e-2/0/alpha1::boundaryField::wall.4 from line 263883 to line 263885. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/newFvPatchField.C at line 110. I use constantAlphaContactAngle patch instead of simply wall. Thanks andrea |
February 14, 2011, 08:16 |
#31 |
Martin
Rep Power: 22 |
Hi Andrea,
to use the writeGradientAlpha1 tool in OpenFOAM-1.7.0 replace the lines in writeGradientAlpha1/Make/options with: Code:
EXE_INC = \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ -ltwoPhaseInterfaceProperties \ -lincompressibleTransportModels \ -lincompressibleTurbulenceModel \ -lincompressibleRASModels \ -lincompressibleLESModels \ -lfiniteVolume wclean wmake Martin |
February 14, 2011, 08:57 |
#32 |
Andrea Ferrari
Rep Power: 17 |
Thanks Martin,
the correct library for the interface properties is : -linterfaceProperties \ . I had an error with -ltwoPhaseInterfaceProperties \. Thanks again andrea |
February 17, 2011, 09:13 |
#33 |
Andrea Ferrari
Rep Power: 17 |
Hi Martin
I tried to edit your file to calculate the curvature of the interface, according to the calculations found in interfaceProperties.C Attached my writeCurvature.C. i got this error SOURCE=writeCurvature.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/transportModels/interfaceProperties/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/incompressible/turbulenceModel -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/writeCurvature.o In file included from /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:1273, from /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.H:586, from /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /opt/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/volFields.H:37, from writeCurvature.C:35: /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C: In function â: /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:950: instantiated from â writeCurvature.C:98: instantiated from here /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:950: error: no matching function for call to â /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/scalarField.H:77: note: candidates are: void Foam::add(Foam::Field<double>&, const Foam::scalar&, const Foam::UList<double>&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/scalarField.H:77: note: void Foam::add(Foam::Field<double>&, const Foam::UList<double>&, const Foam::scalar&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/labelField.H:53: note: void Foam::add(Foam::Field<int>&, const Foam::label&, const Foam::UList<int>&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/labelField.H:53: note: void Foam::add(Foam::Field<int>&, const Foam::UList<int>&, const Foam::label&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:950: instantiated from â writeCurvature.C:98: instantiated from here /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:950: error: no matching function for call to â /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/scalarField.H:77: note: candidates are: void Foam::add(Foam::Field<double>&, const Foam::scalar&, const Foam::UList<double>&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/scalarField.H:77: note: void Foam::add(Foam::Field<double>&, const Foam::UList<double>&, const Foam::scalar&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/labelField.H:53: note: void Foam::add(Foam::Field<int>&, const Foam::label&, const Foam::UList<int>&) /opt/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/labelField.H:53: note: void Foam::add(Foam::Field<int>&, const Foam::UList<int>&, const Foam::label&) make: *** [Make/linux64GccDPOpt/writeCurvature.o] Error 1 what the problem for you? andrea |
February 17, 2011, 09:36 |
#34 |
Martin
Rep Power: 22 |
Hi Andrea,
without doing testing, just removed some typos... have a look... Martin |
February 22, 2011, 06:50 |
#35 |
Andrea Ferrari
Rep Power: 17 |
It runs!
do you know what OF calculate in these lines? const surfaceVectorField& Sf = mesh.Sf(); surfaceScalarField nHatf_ = nHatfv & Sf; thanks andrea |
February 22, 2011, 06:58 |
#36 |
Martin
Rep Power: 22 |
The face unit interface normal flux...
See the comments here, line 00113ff: http://foam.sourceforge.net/doc/Doxy...8C_source.html Martin |
February 22, 2011, 08:21 |
#37 |
Andrea Ferrari
Rep Power: 17 |
Yeah,
but what does it means? If i want the geometric curvature of the interface ([1/L]) which is linked to the capillary pressure that i would like to calculate, do i need the flux? Or is OF that needs the flux to calculate the interfacial forces to put in the equation? thanks andrea |
February 25, 2011, 11:37 |
#38 |
Andrea Ferrari
Rep Power: 17 |
I still have a problem when i calculate the curvature. I find high value of curvature where there is no interface (values higher than the values at the interface!!)and that's no possible. what is wrong? thanks andrea |
December 21, 2016, 10:26 |
Unknown patchField type constantAlphaContactAngle for patch type patch in OpenFOAM
#39 |
Shen shiquan
Location: The State Key Laboratory of Engines (Tianjin University)
Rep Power: 10 |
hello, foamers
I encounter a problem, when initializes the alpha in 0 files as bellow. i don't know why. anyone can help me. thank you for your help in advance Unknown patchField type constantAlphaContactAngle for patch type patch Valid patchField types are : 62 ( advective calculated codedFixedValue codedMixed cyclic cyclicACMI cyclicAMI cyclicSlip directionMixed empty externalCoupled fan fanPressure fixedFluxPressure fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedPressureCompressibleDensity fixedValue freestream freestreamPressure inletOutlet inletOutletTotalTemperature mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mixed nonuniformTransformCyclic oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip phaseHydrostaticPressure prghPressure processor processorCyclic rotatingTotalPressure sliced slip symmetry symmetryPlane syringePressure timeVaryingMappedFixedValue totalPressure totalTemperature turbulentInlet turbulentIntensityKineticEnergyInlet uniformDensityHydrostaticPressure uniformFixedGradient uniformFixedValue uniformInletOutlet uniformJump uniformJumpAMI uniformTotalPressure variableHeightFlowRate waveSurfacePressure waveTransmissive wedge zeroGradient ) |
November 28, 2017, 06:34 |
#40 | |
David GISEN
Rep Power: 17 |
cv.ref() = mesh.V(); |
cell volume, mesh.v, volume |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 14:06 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
how to write the value of every cell in a volume? | Ralf Schmidt | FLUENT | 0 | January 9, 2006 06:18 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
