Can anybody explain my log file
Old   December 7, 2010, 00:45
Default Can anybody explain my log file
Sandeep
gandesk is on a distinguished road
I am using InterFoam for my case to track interface between air and a fluid. I have defined my time step as 0.00001 sec. But in the log file I could not find any where this time step. Could anyone please explain me the calculation process adopted by OpenFoam for solving my case. I am not goot at C++ coding and finding tough time to understand the ternminology. Please look at my log file below:
Courant Number mean: 0.000858798 max: 0.467166
deltaT = 4.54545e-05
Time = 4.54545e-05
MULES: Solving for gamma
Liquid phase volume fraction = 0.00100215 Min(gamma) = 0 Max(gamma) = 1
DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.0498366, No Iterations 14
DICPCG: Solving for pd, Initial residual = 0.00660154, Final residual = 0.000313121, No Iterations 88
DICPCG: Solving for pd, Initial residual = 0.00359337, Final residual = 9.49349e-08, No Iterations 258
time step continuity errors : sum local = 7.03276e-10, global = -4.4511e-12, cumulative = -4.45109e-12
ExecutionTime = 8.59 s ClockTime = 12 s
Courant Number mean: 0.00152963 max: 3.92326
deltaT = 5.75374e-06
Time = 5.12083e-05
DICPCG: Solving for pd, Initial residual = 0.0994367, Final residual = 0.00347591, No Iterations 10
DICPCG: Solving for pd, Initial residual = 0.00420006, Final residual = 0.000189103, No Iterations 9
DICPCG: Solving for pd, Initial residual = 0.000579272, Final residual = 9.65273e-08, No Iterations 223
time step continuity errors : sum local = 1.83072e-10, global = -4.23804e-12, cumulative = -8.68914e-12
ExecutionTime = 12 s ClockTime = 16 s
gandesk is offline   Reply With Quote
Old   December 7, 2010, 03:15
Martin
MartinB will become famous soon enough
you must disable the adjustTimeStep option in "system/controlDict":
adjustTimeStep  no;
Otherwise the max courant number limits the time step.
Martin
MartinB is offline   Reply With Quote
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 09:10
Log File too Large Julian K. OpenFOAM Running, Solving & CFD 17 February 15, 2019 06:56
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
