simpleFoam Blows up with Parabolic Inlet Pipe Flow |
December 6, 2010, 20:37 |
#1 | |||
Stefano Wahono
Rep Power: 16 |
Hi All,
I am simulating a pipe with sudden expansion with a parabolic inlet velocity using simpleFoam. The simulation started with laminar for 2000 iterations (residuals flat off after this) - solution attached. Quote:
The simulation crashed after 2 iterations! Consistently. Error message indicate divide by zero problem for k and epsilon (See below). Please NOTE that if I use NON-parabolic inlet (i.e. fixedValue), everything is fine - I got a good converged solution. I used Upwind Div scheme with cellLimited interpolation scheme. I have tried both PCG and GAMG for pressure, and PBiCG and GAMG for U|k|epsilon. I have also tried varying URF. I suspect the problem is in my BCs and bad starting solution for k and epsilon (since the flow is now parabolic from the inlet). But, I can't figure out. I've also tried setting parabolic inlet profiles for k and epsilon to no avail. Please Help anyone!. the 0/epsilon: Quote:
I hope I do get any help this time. Please.. It's quite difficult to get help from this forum. Regards, Stefano Code:
Time = 2 DILUPBiCG: Solving for Ux, Initial residual = 0.00855909, Final residual = 7.45812e-10, No Iterations 17 DILUPBiCG: Solving for Uy, Initial residual = 0.0467024, Final residual = 6.71306e-10, No Iterations 17 DILUPBiCG: Solving for Uz, Initial residual = 0.0490525, Final residual = 5.95911e-10, No Iterations 18 GAMG: Solving for p, Initial residual = 0.192423, Final residual = 8.18271e-11, No Iterations 40 GAMG: Solving for p, Initial residual = 0.0344647, Final residual = 6.74495e-11, No Iterations 35 GAMG: Solving for p, Initial residual = 0.0101951, Final residual = 7.61577e-11, No Iterations 32 time step continuity errors : sum local = 8.98665e-13, global = 1.02105e-14, cumulative = 6.25679e-15 [4] #0 Foam::error::printStack(Foam::Ostream&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #2 __restore_rt at sigaction.c:0 [4] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libincompressibleRASModels.so" [4] #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libincompressibleRASModels.so" [4] #6 Foam::incompressible::RASModels::RNGkEpsilon::correct() in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libincompressibleRASModels.so" [4] #7 main in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/simpleFoam" [4] #8 __libc_start_main in "/lib64/libc.so.6" [4] #9 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/stefano/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/simpleFoam" |
Poiseuille flow (flow in a pipe) in SOLA-VOF. Parabolic distribution of velocities. | Anton | Main CFD Forum | 9 | April 29, 2009 11:31 |
Pulsating flow with non-reflective inlet boundary | cc1000 | CFX | 6 | April 27, 2009 09:10 |
Urgent: Modeling the drag on a stationary sphere in a parabolic Pres driven pipe flow | farhan | CFX | 4 | April 9, 2009 01:36 |
pulsating static pressure around zero at pipe flow | David Kim | FLUENT | 0 | May 16, 2006 14:47 |
flow in pipe with momentum and energy source | Atit Koonsrisuk | CFX | 3 | March 29, 2005 17:58 |
