December 6, 2010, 02:59 |
RanzMarshall dieselfoam
Rickard
Rep Power: 16 |
I get this error message, anyone recognize it ?
Dividing by zero in RanzMarshall [28] #0 Foam::error:rintStack(Foam::Ostream&) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libOpenFOAM.so" [28] #1 Foam::sigFpe::sigFpeHandler(int) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libOpenFOAM.so" [28] #2 __restore_rt at sigaction.c:0 [28] #3 pow.L in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/dieselFoam" [28] #4 Foam::RanzMarshall::Nu(double, double) const in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so" [28] #5 Foam::RanzMarshall::relaxationTime(double, double, double, double, double, double) const in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so" [28] #6 Foam:arcel::setRelaxationTimes(int, double&, Foam::Field<double>&, double&, Foam::Field<double>&, Foam::spray const&, double, Foam::Vector<double> const&, double, double, Foam::Field<double> const&, Foam::Field<double> const&, double) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so" [28] #7 Foam:arcel::move(Foam::spray&) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so" [28] #8 Foam::spray::inject() in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so" [28] #9 Foam::spray::evolve() in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so" [28] #10 main in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/dieselFoam" [28] #11 __libc_start_main in "/lib64/libc.so.6" [28] #12 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/dieselFoam" |
December 6, 2010, 09:21 |
Nakul
Rep Power: 16 |
Hi
This might be happening due to wrong initialisation of the fields in 0 directory. For knowing any other reasons you need to provide additional details about your case. |
December 7, 2010, 02:41 |
Rickard
Rep Power: 16 |
It happens after i while actually, and I have been checking the doxygen,
I mean my initial field has non-zero values in the zero-directory. On row 95, its like im dividing by zero but it shouldnt be possible (zero mass) scalar RanzMarshall::Nu 00077 ( 00078 const scalar ReynoldsNumber, 00079 const scalar PrandtlNumber 00080 ) const 00081 { 00082 return 2.0 + preRePrFactor_ * pow(ReynoldsNumber, ReExponent_) * pow(PrandtlNumber, PrExponent_); 00083 } 00084 00085 scalar RanzMarshall::relaxationTime 00086 ( 00087 const scalar liquidDensity, 00088 const scalar diameter, 00089 const scalar liquidcL, 00090 const scalar kappa, 00091 const scalar ReynoldsNumber, 00092 const scalar PrandtlNumber 00093 ) const 00094 { 00095 scalar time = liquidDensity*pow(diameter, 2.0)*liquidcL/(6.0*kappa*Nu(ReynoldsNumber, PrandtlNumber)); 00096 00097 time = max(SMALL, time); 00098 00099 return time; 00100 } 00101 00102 scalar RanzMarshall::fCorrection(const scalar z) const 00103 { 00104 scalar correct; 00105 if (z > 0.01) 00106 { 00107 if (z < 1.0e+5) 00108 { 00109 correct = z/(exp(z) - 1.0); 00110 } 00111 else 00112 { 00113 correct = SMALL; 00114 } 00115 00116 } 00117 else 00118 { 00119 // taylor-expansion of exp(z)... 00120 correct = 1.0/(1+0.5*z); 00121 } 00122 00123 return correct; |
December 7, 2010, 03:59 |
Nakul
Rep Power: 16 |
Hi
You should provide a little bit more details about your case. What exactly are you doing? This error occurs mainly due to wrong setup of the test case. There are many reasons for that. You may provide some more information. |
injector model in dieselFoam | leejc | OpenFOAM | 8 | April 3, 2018 12:30 |
Running dieselFoam error | adorean | OpenFOAM Running, Solving & CFD | 119 | February 1, 2016 14:41 |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
axi-symmetric mesh of dieselFoam | az1362f | OpenFOAM Running, Solving & CFD | 2 | June 27, 2009 11:32 |
DieselFoam does not restart from latestTime | lord_kossity | OpenFOAM Bugs | 8 | February 21, 2009 13:54 |
