Regarding periodic BC in ICEM generated grid
Like Tree2Likes
Old   December 20, 2012, 14:57
Default Similar problem with createPatch
  #21
Warren Lamont
wlamont is on a distinguished road
I get the following error:
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'patches' on line 49 and ending at line 159"
file: /home/wlamont/OpenFOAM/wlamont-2.1.1/run/dp73/system/createPatchDict at line 159.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file lnInclude/IOerror.C at line 132.
FOAM exiting
Attached is my createPatchDict which is stored in my system folder:
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
//   a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
//   is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// - always: remove zero-sized (non-coupled) patches (that were not added)
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
//   and centre to make matching easier
// - always create both halves in one invocation with correct 'neighbourPatch'
//   setting.
// - optionally pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
//  "face 0 area does not match neighbour 2 by 0.0100005%"
//  " -- possible face ordering problem."
// - in polyMesh/boundary file:
//      - loosen matchTolerance of all cyclics to get case to load
//      - or change patch type from 'cyclic' to 'patch'
//        and regenerate cyclic as above
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
// Patches to create.
patches
        // Name of new patch
        name per1a;
        // Dictionary to construct new patch from
        patchInfo
            type cyclic;
            neighbourPatch per1b;
	    matchTolerance  0.1;
            // Optional: explicitly set transformation tensor.
            // Used when matching and synchronising points.
            transform rotational;
            rotationAxis (0 0 1);
            rotationCentre (0 0 0);
        // How to construct: either from 'patches' or 'set'
        constructFrom patches;
        // If constructFrom = patches : names of patches. Wildcards allowed.
        patches (per1a-part_3-5450200-101_aero1v);
        // If constructFrom = set : name of faceSet
        set f0;
        name per1b;
        patchInfo
            type cyclic;
            neighbourPatch per1a;
 	    matchTolerance  0.1;
        patches (per1b-part_3-5450200-101_aero1v);
        set f0;
        name per1asolid;
        patchInfo
            type cyclic;
            neighbourPatch per1bsolid;
 	    matchTolerance  0.1;
        patches (per1a-part_3-solid);
        set f0;
        name per1bsolid;
        patchInfo
            type cyclic;
            neighbourPatch per1asolid;
 	    matchTolerance  0.1;
        patches (per1b-part_3-solid;
        set f0;
Any help would be greatly appreciated.
wlamont is offline   Reply With Quote
Old   December 21, 2012, 02:42
maddalena's Avatar
maddalena
maddalena will become famous soon enough
says that something is wrong at line 49. Look at your line 49 and compare with this file: $FOAM_UTILITIES/mesh/manipulation/createPatch/createPatchDict.
See here as well.
mad
maddalena is offline   Reply With Quote
Old   April 21, 2013, 03:55
Esmaeil Ahmadiyan
e.ahmadiyan is on a distinguished road
Hi dear Gabriel
I am same problem as you.
If you were successful in resolve this problem please give your experiences to me.
Thanks
Best regards
e.ahmadiyan
e.ahmadiyan is offline   Reply With Quote
Old   April 21, 2013, 05:34
Qiang
wangqiangele is on a distinguished road
I generated the periodic patches using createPatchDict with the following specifications. (where 25 is the distance between inlet and outlet)
Hope it helps~
Qiang
patches
name inletOutlet_half0;
patchInfo
type cyclic;
neighbourPatch inletOutlet_half1;
transform translational;
separationVector (25 0 0);
patches (inlet);
set f0;
name inletOutlet_half1;
patchInfo
type cyclic;
neighbourPatch inletOutlet_half0;
separationVector (-25 0 0);
patches (outlet);
set f0;
Originally Posted by e.ahmadiyan View Post
Hi dear Gabriel
Thanks
wangqiangele is offline   Reply With Quote
Old   April 21, 2013, 08:22
Esmaeil Ahmadiyan
Hi dear Qiang
Thanks for your reply very much.
My geometry and createPatchDict file are as below:
createPatchDict.zip
When running the case this error reported:
This probably means your geometry is not consistent with the specified separation and might lead to problems.
Continuing with specified separation vector (0.0002 0 0.0002)
patchutlet1 neighbour:inlet1
--> FOAM Warning :
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 368
In your mind are there any incorrect setting in createPatchDict file proportional to geometry?
What are separationVector and rotationAxis and rotationCentre ? please demonstrate for me. In fact I do not know how I should adjust this parameters in createPatchDict file proportional to my geometry.
All my case is as below
cyclic.zip
Thanks
Best regards
e.ahmadiyan
Old   April 21, 2013, 09:50
Qiang
I am not sure about your case.
Maybe you can specify
rotationAxis ( 0 0 1 );//maybe(0 0 -1)
rotationCentre ( x y 0 );//specify [x,y] to your case to ensure that the outlet boundary meet the inlet boundary after 270 degrees rotation around the center (anticlockwise)
Best,
Qiang
Hi dear Qiang
Attachment 20981
Attachment 20982
--> FOAM Warning :
Attachment 20983
Thanks
Old   April 21, 2013, 10:22
Esmaeil Ahmadiyan
Dear mad
Have you any more suggestion ?
Best regards
e.ahmadiyan
Old   April 22, 2013, 09:00
maddalena's Avatar
maddalena
Dear mad
(25 0 0) is NOT the separation vector between the two. inlet and outlet are rotated as well.
mad
Old   April 22, 2013, 10:01
Esmaeil Ahmadiyan
Dear mad
What is your suggestion about my geometry and createPatchDict that I was mentioned in above post numbering 25? please
Best regards
e.ahmadiyan
Old   April 22, 2013, 10:32
maddalena's Avatar
maddalena
Dear mad
My suggestion is to think once again to your case and to play a bit with createPatchDict. This is the way openFoam works.
mad
Old   April 30, 2013, 08:10
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi guys,
I have a similar problem for defining cyclic boundary conditions but here for unstructured grids.
Well as you know cyclic boundary conditions defining is a bit different since OF 2.0.0, So as I understood, there is no need to use createPatch utility anymore. (Please correct me if I am wrong)
Here is the page for new features of OF 2.0.0:
http://www.openfoam.org/version2.0.0/meshing.php
as you can see, cyclic boundary conditions are defined like this (in boundary file):
patch0_half0
type cyclic;
nFaces 256;
startFace 11520;
matchTolerance 0.0001;
neighbourPatch patch0_half1;
patch0_half1
type cyclic;
nFaces 256;
startFace 11776;
neighbourPatch patch0_half0;
So I did the same work and defined my cyclic patches like this:
inlet
type cyclic;
nFaces 543;
startFace 281225;
neighbourPatch outlet;
outlet
type cyclic;
nFaces 530;
startFace 281768;
neighbourPatch inlet;
but there is a problem here. As you can see, the number of faces is different between inlet and outlet patches. one is 543 and the other is 530.
by running checkMesh I get the following error:
--> FOAM FATAL ERROR:
For patch inlet there are 543 face centers, for the neighbour patch outlet there are 530
So its needed to make these numbers equal. But how is that possible for unstructured grids? any suggestions is greatly appreciated.
FYI: I am using ICEM to generate the mesh.
Thanks,
Mojtaba
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   April 30, 2013, 11:09
maddalena's Avatar
maddalena
Simple. create them equal in your meshing software...
Copy-paste worked as a charm in the past for me.
mad
Mojtaba.a likes this.
Old   April 30, 2013, 15:46
Mojtaba.a's Avatar
mad
Thank you maddalena, I will try. beginner in ICEM
But am I correct? Is there any need of createPatch utility for cyclic patches anymore?
[ICEM] Exporting Grid Volumes/Areas from ICEM to Calculate Discretization Error Josh ANSYS Meshing & Geometry 4 May 20, 2010 14:40
2D periodic from ICEM to FLUENT Markus FLUENT 1 August 11, 2008 08:13
How make a .gtm grid for pre-CFX using ICEM ????? IGNA CFX 2 January 24, 2007 09:36
Problems in grid generation in ICEM Tim CFX 1 September 30, 2006 07:43
How to import grid generated using ICEM/CFD Harry Siemens 2 April 17, 2006 01:01
