libcompressibleTurbulenceModel.so
Old   November 26, 2010, 04:59
Unhappy libcompressibleTurbulenceModel.so
Farshad
Farshad_Noravesh is on a distinguished road
I am trying to compile reactingFoam and other combustion solvers in openfoam1.7.0
The following error is common in all these compilations:
[farshad@farshad reactingFoam]$ wclean
[farshad@farshad reactingFoam]$ wmake
Making dependency list for source file reactingFoam.C
SOURCE=reactingFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/compressible/turbulenceModel -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/basic/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/ODE/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/reactingFoam.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/compressible/turbulenceModel -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/basic/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/ODE/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/reactingFoam.o -L/home/farshad/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt \
-lcompressibleRASModels -lcompressibleLESModels -lreactionThermophysicalModels -lspecie -lbasicThermophysicalModels -lchemistryModel -lODE -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/farshad/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/reactingFoam
/usr/bin/ld: Make/linux64GccDPOpt/reactingFoam.o: undefined reference to symbol 'Foam::compressible::turbulenceModel::New(Foam::Ge ometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&)'
/usr/bin/ld: note: 'Foam::compressible::turbulenceModel::New(Foam::Ge ometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&)' is defined in DSO /home/farshad/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so so try adding it to the linker command line
/home/farshad/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
make: *** [/home/farshad/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/reactingFoam] Error 1
please tell me where i can find a better source for compressibleturbulence library.
Kind Regards,
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   November 26, 2010, 07:30
Retired Super Moderator
Bruno Santos
Greetings Farshad,
I saw your previous thread yesterday, but I postponed answering to you and eventually forgot to come back
Anyway, my guess is that you're building OpenFOAM 1.7.0 in a Fedora 13 or 14, which is a very relevant information! And for Fedora, you better read this thread: http://www.cfd-online.com/Forums/ope...dora-13-a.html
Best regards and good luck!
Bruno
Old   November 27, 2010, 15:20
Smile except reactingFoam
Farshad
Dear Bruno,
Thanks for your nice help .Following your advice, i could compile all combustion solvers except reactingFoam and it gives me several errors such as:
/home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:153: error: expected ‘;’ before ‘&’ token
/home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:159: error: expected ‘;’ before ‘const’
/home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:159: error: ISO C++ forbids declaration of ‘volVectorField’ with no type
/home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:159: error: expected ‘;’ before ‘&’ token
Again i thank you for your kind help.
Farshad
Old   November 28, 2010, 10:34
Bruno Santos
Hi Farshad,
This is odd... there must have been some other error as well before that, something about a missing header file. Because those errors are indicative of missing header files that define "volScalarField" and "volVectorField".
If you are using Fedora, it would be best to use OpenFOAM 1.7.x.
Best regards,
Bruno
