#21 | |
Diego Villa
Rep Power: 16 ![]() |
The disturbs found by you are due to the velocity flux (seen as a surface vector field) computed in the two zones (within the MRF and out of it). From a mathematical point of view, it assumes different values inside and outside the MRF region. These values are coincident only if the cell's surface (seen as an interface) has a normal vector orthogonal to the imposed motion (in your case, it should be cylindrical). Otherwise, the phi value and the velocity field are not consistent seen from inside and outside the MRF zone. I hope to have clarified the problem, Diego |
#22 | |
Diego Villa
#23 | |
Pedro Gouveia
Rep Power: 3 ![]() |
Thanks, it was clarified completely. By using a cylindrical mesh we grant a relative "orthogonality" between the cells immediately before and after the MRF interface. However, does a regual mesh mean worse results than the cylindrical one? |
#24 | |
Diego Villa
Anyway, if the orthogonally is not too high, the solution converges properly. |
equation, mrf, theory |
rotating wall inside of an MRF zone - fixedValue or movingWallvelocity? | evrikon | OpenFOAM Running, Solving & CFD | 3 | April 30, 2015 03:51 |
Should an empty MRF zone really induce this much cross-flow? | sylvester | OpenFOAM | 5 | November 18, 2010 03:48 |
Spalart-Allmaras model in Ansys Fluent 12.0 theory guide | macfly | FLUENT | 0 | February 7, 2010 17:03 |
Solver Theory | petr | CFX | 0 | April 20, 2005 09:03 |
Moving Mesh and MRF | Romain | FLUENT | 1 | May 16, 2002 03:45 |
