November 19, 2010, 08:51 |
dsmcFoam modified version download
Marta Lazzarin
Rep Power: 17 |
Hi All!
I have implemented a new version of dsmcFoam where it is possible to initialise the particles where desired inside the domain under study and to simulate a pressure-driven flow of particles. I implemented the changes to the code for initialisation and Claus Schmitzer implemented those about the flow modelling. The way everything works is briefly discussed in the document 'dsmcFoamModifications'. The procedure for compiling is explained there, together with a list of the modified classes. Finally, you can find an example test case, which you can use to see how to apply the modifications to your own analysis and also some movies of the results I obtained. If you want to have the new code version, then you can contact me directly because it's impossible to attach it here. Cheers! Marta |
November 19, 2010, 08:56 |
Marta Lazzarin
Rep Power: 17 |
I am sorry, but it is impossible to post here also the pdf file describing the implementation and the compiling procedure, so again, contact me directly if you want this version of the code.
Marta |
November 19, 2010, 10:58 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Marta,
I am interested. Could you please email me the code and the pdf file? Thanks! Pei phsieh2005@yahoo.com |
November 19, 2010, 17:49 |
M K Singh
Rep Power: 17 |
Dear Marta,
Could you please send me the code and pdf to my gmail id: mrityunjay111@gmail.com Thanks in advance. M K |
October 15, 2012, 08:26 |
Hi Marta,
I am really interested on your modification of the DSMC Foam code. Could you please email me your code & the PDF file to the following E-mail address: gleason_cristian@yahoo.com.mx Thanks in advance Cristian |
January 7, 2013, 12:17 |
wenjie
Rep Power: 14 |
Hi, could you please also send me copy? My email is W.JIN-1@tudelft.nl. I am really interested. Thanks a lot!
January 8, 2013, 02:28 |
ethan oh
Rep Power: 15 |
Hi Marta,
I am interested on your modification of the DSMC Foam code. Could you please send me your code & the PDF file to the following E-mail address: bibento@naver.com Thanks in advance Ethan |
February 20, 2013, 07:22 |
new dsmc code
#8 | |
murali
Rep Power: 13 |
muraliraja865@yahoo.com thanking you |
May 9, 2013, 10:22 |
#9 |
wanji
it has been included in openfoam
May 30, 2013, 01:41 |
#10 |
Rep Power: 15 |
That's great news! Could you plz send the files to my email sreyasmary@gmail.com Thanks in advance |
June 14, 2013, 06:55 |
#11 |
Rep Power: 13 |
Hello Marta !
I am interested in the modification you added to dsmcFoam. Could you please send the code and the .pdf at my e-mail address ? sylvain.fuertes@gmail.com Thanks in advance, Sylvain |
September 17, 2013, 00:49 |
#12 |
hhy
Hello Marta !
I am interested in the modification you added to dsmcFoam. Could you please send the code and the .pdf at my e-mail address ? scuhhy@gmail.com Thanks in advance, |
December 17, 2013, 08:02 |
dsmcModFoam
#13 |
believe sun
Hi, Marta,
I am interested in dsmcModFoam and downloaded it in www.physimmasters.com ,but i can not run it succesful. maybe there are some setting errors in contorlDict, i don not know how to solve it. can you give me a case file including 0 , constant, system folder using dsmcModFoam . thank you very much! my e-mail address believesds@gmail.com hoping for your reply. |
May 4, 2014, 16:06 |
please help me
#14 | |
christos
Dear Marta,
Could you please send me the code and pdf to my mail id: christantos@mie.uth.gr Thanks in advance. C. T. Quote:
June 23, 2014, 09:12 |
requesting code and pdf
#15 | |
reza
Could you please send me the code and pdf to my email: rahaieee@yahoo.com Thanks in advance. R. R. |
March 20, 2015, 14:30 |
#16 |
Nadish Saini
Rep Power: 12 |
Hello Marta,
I am interested in performing pressure driven DSMC simulation. I could not find a link to download the file from http://www.physimmasters.com/. Could you please e-mail me the code and PDF @ nadishsaini@gmail.com. Thank you very much. |
March 22, 2016, 08:20 |
#17 |
sreelalmr
I am doing experiments in rarefied gas dynamics. Can you send the modified pressure driven code and manuals to do a parametric study. Because doing experiment n large manner is very expensive..
Regards Sreelal |
June 6, 2016, 02:22 |
#18 |
Shesh
Rep Power: 11 |
could you please send me the code and pdf, my email id is sheshdhurandhar@gmail.com.
Thank you in advance. |
June 7, 2016, 12:13 |
#19 |
Akshay
Could you please mail the modified code to AkshayMAnvekar@gmail.com.
Thanks |
June 20, 2016, 10:02 |
#20 |
Rep Power: 12 |
may I ask for the modified code and the pdf as well? My email address is tomas.tisovsky@tul.cz Thank you in advance. |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
bubbleFoam validation case | balkrishna | OpenFOAM Running, Solving & CFD | 24 | August 30, 2010 05:37 |
[OpenFOAM] Problem with paraFoam on a linux-64 bit | bunni | ParaView | 4 | April 14, 2010 21:55 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
Version 141 download | joern | OpenFOAM Installation | 6 | January 19, 2009 05:36 |
