November 15, 2010, 09:19 |
Compiling Probelm with new BC
Christian Lucas
Rep Power: 18 |
I want to rewriting rhoPisoFoam by including a totalEnergyEquation. For this, I need to include a new field for the total Enthalpy, which needs new Boundary Conditions. I used the rho boundary condition files from rhoCentralFoam as a starting point. The new BC files ("fixedTotalEnthalpyFvPatchScalarField) compile without a problem. When I want to compile the solver, I get the following error message: SOURCE=rhoPisoFoam2.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/lnInclude -IBC/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoPisoFoam2.o /opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’: /opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable ‘nOuterCorr’ g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/lnInclude -IBC/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/rhoPisoFoam2.o -L/opt/openfoam171/lib/linux64GccDPOpt \ -lfiniteVolume -lmeshTools -lbasicThermophysicalModels -lspecie -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lOpenFOAM -liberty -ldl -lm -o /opt/openfoam171/applications/bin/linux64GccDPOpt/rhoPisoFoam2 Make/linux64GccDPOpt/rhoPisoFoam2.o: In function `main': rhoPisoFoam2.C.text+0x1ab1): undefined reference to `Foam::fixedTotalEnthalpyFvPatchScalarField::typeN ame' collect2: ld returned 1 exit status It seems that the problem is related to "Foam::fixedTotalEnthalpyFvPatchScalarField::typeN ame", which should be the name of the new BC. The error message says that the called function is not found, but it is defined in fixedTotalEnthalpyFvPatchScalarField.H. Could the problem be related to the parent class used for "fixedTotalEnthalpyFvPatchScalarField.H" Regards, Christian |
November 15, 2010, 09:47 |
Stefan Herbert
Rep Power: 17 |
Hi Christian,
did you include the new library containing this BC in your EXE_LIBS inside Make/options of the solver? Regards, Stefan |
November 15, 2010, 10:09 |
Christian Lucas
Rep Power: 18 |
thanks for the reply, help a lot . The problem was related the name I gave the dynamic library file of fixedTotalEnthalpyFvPatchScalarField in BC/make/option I used a different name in the option file of the solver, so the compiler could find the library Regards, Christian |
Help with KIVA4 source code compiling | geothokar | Main CFD Forum | 0 | September 3, 2010 05:40 |
error msg when compiling user fortran | Ollimarc | CFX | 0 | March 13, 2008 18:16 |
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 | sponiar | OpenFOAM Running, Solving & CFD | 3 | February 26, 2008 06:31 |
Discussing UDF and C++ Compiling | Big Stone | FLUENT | 9 | April 12, 2004 15:07 |
Compiling | MON | FLUENT | 0 | October 20, 2002 20:48 |
