How to add a summison term in the source code
Old   November 8, 2010, 01:03
Default How to add a summison term in the source code
Nakul
nakul is on a distinguished road
I want to add a term like: Σaibi; i=1,2,...,n to a solver's governing equations.
Is there any inbuilt function in
openfoam that can be used to sum the individual terms
I don't think I can use for loop to add the terms because the values of these parameters are obtained simultaneoulsy by the solution of the governing equations.
Any help would be appreciated!!
Thanx
nakul is offline   Reply With Quote
Old   November 8, 2010, 05:28
Steven van Haren
stevenvanharen is on a distinguished road
if a and b are vectors you can use the inner product operator
look at page 18 and 23 of the programmer's guide.
stevenvanharen is offline   Reply With Quote
Old   November 8, 2010, 08:00
Patricia
schmittp54 is on a distinguished road
I am not sure if I understand your question correctly.
If both the ai and bi are part of your solution vector and you solve an equation including a*b on the left hand side (like M(a,b)+a*b=c), this is a nonlinear equation. Linearize the equation and you will be able to add the linearized expression for a*b as a source term.
Patricia
schmittp54 is offline   Reply With Quote
Old   November 9, 2010, 01:38
Nakul
Hi Patricia,
To be more specific I want to code the energy equation for combustion. The energy equation is in the form, shown in the attached screenshot.
The "summision" term that I want to code is the equ. (1. 48) in the screenshot. And this energy equation needs to be solved simultaneously with continuity, momentum and species equations.
So my question is how can I code this term in the OpenFOAM's source code?
I would be adding this term to the energy equation of rhoCentralFoam.
Old   November 9, 2010, 04:56
Patricia
Hi Nakul,
unfortunately the screenshot is still not a complete description of the problem. Maybe you can start coding a solver using similar principles as in the existing OpenFoam solvers. Then describe where your solver fails, and people will be able to assist.
If you want to solve for all variables simultaneously, you have to wait until OpenFoam supports block matrices, and even then you have to linearize the problem. But I don't see why you'd need block matrices. Why not start with a loop summing over the species instead of giving up before you have tried?
Patricia
Old   November 9, 2010, 05:17
Nakul
Hi Patricia,
Actually I was just mentioning the equation, that I want to code, in the screenshot.
The problem is that I am unaware of the correct way to code that summision term in the solver.
All I want to know is that, .if there is some way to add such summision terms.
I don't think that for loop is a correct option because at every time step the values of Yk, ie, the species mass fraction is unkown. They are the variables that are being solved for.
So adding them using a loop might not generate any result.
Old   November 9, 2010, 06:36
Patricia
Yes, but an equation is not a problem description.
I think you should try things out before you think they don't work. Many of the existing solvers show how to solve for variables that are needed simultaneously. Most of them use the segregrated approach which I think will work for you as well. If you don't want to spend any time by yourself, there are companies behind OpenFoam who can do the work for you (no, I am not affiliated to any).
I am out of this discussion. Good luck!
Patricia
Edit: You cannot solve for the Yk from equation 1.48. You need at least N additional equations (transport equations with reaction kinetics?) to get a well posed problem.
UDF source term Rajani Kanth.B Fluent UDF and Scheme Programming 4 May 1, 2013 10:31
Add time dependent Source term libe OpenFOAM Running, Solving & CFD 13 September 23, 2010 10:12
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 04:40
Add a source term into the Y mom. eq. Rucy FLUENT 0 December 12, 2005 05:24
