reactingFoam floating point exception
Old   November 6, 2010, 18:29
Default reactingFoam floating point exception
Paul
pajofego is on a distinguished road
Hello at all,
I'm new in combustion simulation with openfoam. I started to define my own geometry/case with gmsh and the set up I have done similar to the "counterFlowFlame2D" example. So when I start the solver I got a floating point exception at the beginning (after the "Selecting thermodynamics package" step). I'm not sure where to find the error. May be here is someone who can give me some advises.
If necessary I would share my testcase. Here you can find it: http://www.sendspace.com/file/fza8aw
Thanks in advance and best regards
pajofego
pajofego@pajofego-laptop:~/OpenFOAM/pajofego-1.7.1/run/combustion/Brenner$ reactingFoam
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.1-fffd2c682d50
Exec   : reactingFoam
Date   : Nov 06 2010
Time   : 23:10:45
Host   : pajofego-laptop
PID    : 4126
Case   : /home/pajofego/OpenFOAM/pajofego-1.7.1/run/combustion/Brenner
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading chemistry properties
Reading g
Reading thermophysicalProperties
Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics>
Selecting thermodynamics package hsPsiMixtureThermo<reactingMixture<gasThermoPhysics>>
Selecting chemistryReader chemkinReader
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > >::hs(Foam::Field<double> const&, int) const in "/opt/openfoam171/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#4  Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > >::hsPsiMixtureThermo(Foam::fvMesh const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#5  Foam::hsCombustionThermo::addfvMeshConstructorToTable<Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#6  Foam::hsCombustionThermo::NewType(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#7  Foam::psiChemistryModel::psiChemistryModel(Foam::fvMesh const&, Foam::word const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libchemistryModel.so"
#8  Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > >::ODEChemistryModel(Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libchemistryModel.so"
#9  Foam::psiChemistryModel::addfvMeshConstructorToTable<Foam::ODEChemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam::janafThermo<Foam::perfectGas> > > > >::New(Foam::fvMesh const&, Foam::word const&, Foam::word const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libchemistryModel.so"
#10  Foam::psiChemistryModel::New(Foam::fvMesh const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libchemistryModel.so"
#11
 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/reactingFoam"
#12  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#13
Floating point exception
pajofego is offline   Reply With Quote
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 17:34
Cannot Open .sim (Floating Point Exception) trex930 STAR-CCM+ 1 July 30, 2010 07:51
floating point exception? syd STAR-CCM+ 3 April 20, 2010 19:55
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
