October 31, 2010, 00:22 |
problem in converting mesh from fluent
hi Foamers
i am simulating a 2-D case using sonicFoam solver in OF.1.6 but when i convert the mesh file with .msh extension to OF using 'fluentMeshtoFoam' command, it is extruding 8.9 mm in Z direction but i require only 1 mm. how can i do this. regards Ambilpur Kiran |
October 31, 2010, 22:35 |
Masashi Ohbuchi
Rep Power: 17 |
At the line 983 of fluentMeshToFoam.L, 2-dimensional mesh extruded into 3-d. zOffset is restricted in 0.01*bounding Box size of 2-d mesh. So you should modify this in the file and make your custom mesh converter. |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
Problem with 2D ICEM mesh check in fluent | Nicola | FLUENT | 3 | March 25, 2013 06:56 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 03:28 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
A problem about Importing mesh from fluent | aderliner | OpenFOAM Running, Solving & CFD | 0 | December 19, 2006 00:05 |
