October 27, 2010, 16:14 |
rocketFoam
Rep Power: 17 |
Hi you all
We, Terrassa Rocket Team or TRT, are a team formed by students of engineering in aeronautics involved in a project whose aim is to build a rocket capable of lifting a 1 kg payload to an altitude of, at least, 100 km if launched from a balloon launcher, which is being developed by another team of students. One teammate and I are by now in charge of obtaining aerodynamic forces produced on our rocket model by using OpenFOAM. So far, after completing the Cavity tutorial and learning the basics, we have been able to mesh a domain with our rocket model inside it by using snappyHexMesh, and run a simulation using the simpleFoam solver. Given this situation, now we face the following problems. 1st) We have been unable to run the case in rhoSimpleFoam (always because of a floating point exception). Although the incompressible solver may give us an approximate magnitude of the forces involved, it would be great if we could run it compressible. 2nd) We still need to find a way of computing resulting forces on the rocket, or their coefficients. Although after a quick search several possible options arose for the second problem, we'll be soon facing our partial exams for this quarter, and thus further testing is stopped until their end on November, Friday 12, 2010. By the meanwhile, if you could share any advice on the matter, that would be really great, we'll thank any kind of help. Finally I'd like to show you this images from our simulation using a free stream at 200 m/s and a 10° angle. Surface color by p, streamlines color by U. Note the mesh is still coarse, since we've been running only test cases. Thanks for reading TRT This is our blog: http://terrassarocketteam.blogspot.com/ |
October 29, 2010, 06:09 |
Rep Power: 19 |
Hi guys,
sounds interesting what you are doing. Concerning the floating point exception: how is your courant-number doing? is it exceeding? Anything above 1 for OF is exceeding. I'm not sure if there is a specific recommended value for your solver or not but I usually try to keep it lower than 0.8. So maybe check your time steps and mesh density again. to the second problem with the forces. I calculate my (buoyant) forces on a ship hull with an appendix to the controlDict file: Code:
maxCo 0.8; maxAlphaCo 0.8; maxDeltaT 1; // ************************************************************************* // functions ( forces { type forces; functionObjectLibs ("libforces.so"); //Lib to load outputControl timeStep; outputInterval 1; patches (B319_comp_patch0); // change to your patch name rhoInf 1000; //Reference density for fluid nuInf 1e-6; //Reference kinetic viscosity for fluid CofR (0 0 0); //Origin for moment calculations } forceCoeffs { type forceCoeffs; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches (B319_comp_patch0); //change to your patch name rhoInf 1000; nuInf 1e-6; CofR (0 0 0); liftDir (0 0 1); dragDir (-1 0 0); pitchAxis (0 1 0); magUInf -7.1; lRef 1; Aref 1; } ); However I didn't code these lines myself and I'm not familiar with what kind of forces you need in particular. So maybe you have to do some adjustments and/or do something completely different. This is just a hint and not the necessarily the absolute truth I hope I could help and did not confuse you best regards Colin |
November 16, 2010, 07:15 |
Rep Power: 17 |
Hi, colinB
Thanks for your advice. About the compressible solver, I believe too that the origin of the problem is the coarse mesh we are using at this point. We'll try to refine it as well as reduce time steps too, and check again if it works. And about the forces, I had a "U, p or rho not found in database - De-activating Forces" problem until I added the following line to the script you posted, just before "rhoInf" "rhoName rhoInf;" I believe this happens because of using OpenFOAM version 1.7.1, but I'm not completely sure about that. After adding that line it worked like a charm. Thanks for reading and for your help again. TRT |
