Accessing LES Delta Values From Solver Code
Old   October 25, 2010, 18:46
Default Accessing LES Delta Values From Solver Code
Matthew J. Churchfield
mchurchf is on a distinguished road
I am trying to make a modification to buoyantBoussinesqPisoFoam in which the turbulent Prandtl number is a function of the LES filter width. Is there any way to access the LES filter width field from buoyantBoussinesqPisoFoam.C? I tried turbulence->delta(), but that does not work.
Thank you,
Matt
mchurchf is offline   Reply With Quote
Old   December 8, 2012, 16:44
hz283 is on a distinguished road
Hi Matt,
Did you solve this problem?
I am using rhoPimpleFoam and LES Smagorinsky model. The filter width delta is used in the simulation. Now I would like to use delta() to output another quantity (it is volScalarField type), and I think I can add somes lines in creatFields.H. However, I had some problems about how to use the fileter delta () in createFields.H of rhoPimpleFoam. Thank you very much.
hz283 is offline   Reply With Quote
Old   June 12, 2023, 04:14
Sarah
Sarah13 is on a distinguished road
Hi
Can anyone please let me know here that how can I access LES delta in my solver code, as I am new to cpp so I don't have much idea and whatever attempts I made, I wasn't successful. What can I add to createfields to call the LESModel class and access its member function delta in my code.
Thanks in advance
Sarah13 is offline   Reply With Quote
Old   June 12, 2023, 12:43
Chris Sideroff
cnsidero is on a distinguished road
If you're using rhoPimpleFoam, you should be able to get the deltas with the following:
turbulence->delta()
Untested though. And if it works, you'll have to be careful using it because the LES delta() function is only available when LESModels are used but rhoPimpleFoam also works with RASModels.
cnsidero is offline   Reply With Quote
Old   June 12, 2023, 13:55
Sarah
Hi Chris
Thanks a lot for your reply. I am using XiFoam solver and the code you mentioned is not working for me, although both rhoPimpleFoam and XiFoam use the same class for momentum transport model.
It is giving me this error.
‘class Foam::CompressibleMomentumTransportModel<Foam::flu idThermo>’ has no member named ‘delta’; did you mean ‘devTau’?
Please if you can help me further regarding this.
Thank you
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
Getting values from fluent solver Moshiur R. Chowdhury FLUENT 2 November 27, 2002 14:41
LES Code gupta Main CFD Forum 0 September 21, 1999 16:11
2D LES Code for Bluff Bodies Patku Main CFD Forum 17 July 31, 1999 19:59
