Forces calculation
Old   October 22, 2010, 12:53
Default Forces calculation
fusij is on a distinguished road
Hello OpenFOAM users&fans,
I am new to OpenFOAM and I am simulating a 2D flow over a cylinder with pisoFoam.
When I am trying to find the forces, the forces.dat file only shows brackets full of zeros. The forces code seen below creates a forces/0 folder where forces.dat is located. I am referring to the right patch in the code. Do you have some suggestions or ideas of what could be wrong?
This is my forces code in my controlDict.h
functions
forces
type forces;
functionObjectLibs ( "libforces.so" ); outputControl timeStep;
outputInterval 1;
patches (wall);
pName p;
UName U;
log true;
rhoName rhoInf;
rhoInf 1025;
CofR ( 0 0 0 );
fusij is offline   Reply With Quote
Old   October 29, 2010, 11:23
Nick Gardiner
NickG is on a distinguished road
Hi
Is your cylinder named wall? If not change the
patches (wall);
line in forces{... } to
patches (whatever you've called it);
Hope that helps
Nick
NickG is offline   Reply With Quote
Old   October 29, 2010, 11:30
Vesselin Krastev
vkrastev is on a distinguished road
If the patch name is correct, try also to remove the lines beginning with pName and Uname: judging by other treads in the forum, these lines can give some troubles in the 1.7.x versions of OpenFOAM.
Regards
V.
vkrastev is offline   Reply With Quote
Old   October 29, 2010, 11:50
Juanito
Aerospace is on a distinguished road
Any one knows if there are problems with force function in 3D multifaces patch?
Thankyou.
Aerospace is offline   Reply With Quote
Old   October 29, 2010, 12:38
It was just a stupid mistake, for some reason I had changed my patch name to something else than "wall". It is fixed now, thank you.
Forces viscous calculation in VWT with OpenFOAM 15x terrybarnaby OpenFOAM Running, Solving & CFD 0 November 28, 2008 09:39
Calculation of pressure forces in Fluent Maharba FLUENT 2 June 29, 2007 02:14
forces calculation Chien CFX 9 June 23, 2005 12:45
Warning 097- AB Siemens 6 November 15, 2004 05:41
Calculation of forces Michal Marcinkowski Main CFD Forum 2 January 18, 2001 05:37
