boundary condition scalarField in parallel
Old   October 13, 2010, 12:01
Default boundary condition scalarField in parallel
nlc
nlc's Avatar
Nicolas Lussier Clément
nlc is on a distinguished road
I'm trins to compile my boundary condition using a scalarField It work but in parallel I get this warning:
  --> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/niko/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/Field.C at line 262
    Reading "/home/niko/OpenFOAM/niko-1.7.1/run/AEMN/testcase/ABL_kepsilonGroundShear/processor0/0/U::boundaryField::ground" from line 102 to line 105
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
And the const scalarField z0_ change but it is not suppose to !
To do this patch I use fixed shear stress and nut rough wall as example.
Thanks for the help !
nlc is offline   Reply With Quote
Old   October 13, 2010, 12:06
nlc
nlc's Avatar
The k file in the 0 folder has the ground boundary define:
    ground
      type ABLz0kWall;
      //z0       uniform 0.1;
      #include        "include/z0Field"
      z0 nonuniform   $z0Field;
      kappa           0.41;
      Cmu             0.09;
with include/z0Field
z0Field            List<scalar>
        75(0.1 0.1 0.1 0.1 0.1
           0.1 0.1 0.1 0.1 0.1
           0.1 0.1 0.1 0.1 0.1
           0.1 0.1 0.1 0.1 0.1
              0.1 0.1 0.1 0.1 0.1
              0.1 0.1 0.1 0.1 0.1
              0.1 0.1 0.1 0.1 0.1
             0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
              0.4 0.4 0.4 0.4 0.4
Old   November 1, 2010, 14:24
nlc
nlc's Avatar
I found an error that solve part of the problem, but now I try to use rmap and automap to make it possible to use in parallel.
My error was that in the write function I did not use the right function too write z0_ so I change it for:
z0_.writeEntry("z0", os);
now z0 write correctly but it is still a problem with parallel since rmap and automap are not define.
I try to add them as it is add in turbulentHeatFluxTemperatureFvPatchScalarField but i get this error:
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C: In member function ‘virtual void Foam::incompressible::RASModels::ABLz0epsilonWallFunction::autoMap(const Foam::fvPatchFieldMapper&)’:
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C:286: error: passing ‘const Foam::scalarField’ as ‘this’ argument of ‘void Foam::Field<Type>::autoMap(const Foam::FieldMapper&) [with Type = float]’ discards qualifiers
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C: In member function ‘virtual void Foam::incompressible::RASModels::ABLz0epsilonWallFunction::rmap(const Foam::fvPatchScalarField&, const Foam::labelList&)’:
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C:296: error: ‘template<class Type> class Foam::fvPatchField’ used without template parameters
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C:304: error: passing ‘const Foam::scalarField’ as ‘this’ argument of ‘void Foam::Field<Type>::rmap(const Foam::UList<T>&, const Foam::unallocLabelList&) [with Type = float]’ discards qualifiers
make: *** [Make/linux64GccSPOpt/ABLz0epsilonWallFunction.o] Erreur 1
thanks for the help
Old   November 2, 2010, 10:54
Talking autoMap tryed to modify my const scalarField z0_ !!
nlc
nlc's Avatar
apparently the too errors
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C:294: error: passing ‘const Foam::scalarField’ as ‘this’ argument of ‘void Foam::Field<Type>::autoMap(const Foam::FieldMapper&) [with Type = float]’ discards qualifiers
and
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C:313: error: passing ‘const Foam::scalarField’ as ‘this’ argument of ‘void Foam::Field<Type>::rmap(const Foam::UList<T>&, const Foam::unallocLabelList&) [with Type = float]’ discards qualifiers
are in my case related to the fact that I used a:
const scalarField z0_;
I change it for a:
scalarField z0_;
And those too error disappear. I guess it means i tried to modify the constant class z0_ with autoMap. So autoMap modify the member of the class !!! One day I'll get use to c++ error message. But now I'm still learning c++ !!
but still this error remains
Wall/epsilonWallFunctions/ABLz0epsilonWallFunction/ABLz0epsilonWallFunction.C:304: error: ‘template<class Type> class Foam::fvPatchField’ used without template parameters
If some one can give me a cue on this error it will help me !!!
Regards
Old   November 5, 2010, 20:26
Thumbs up
nlc
nlc's Avatar
Found the reason for the error :
As rmap is a virtual function and the mother of my class is a template with no rmap define I got confuse. The problem was that I was calling the rmap function without template parameters. So I had to define the parameters I used. In my case : <scalar>.
I use
fvPatchField<scalar>::rmap(ptf, addr);
instead of
fvPatchField::rmap(ptf, addr);
And the error is gone !!
works fine now tanks for reading
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 01:55
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
problem with boundary condition??? smn CFX 5 November 24, 2009 07:37
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
