openfoam 1.7.1 compilation
Old   October 10, 2010, 06:37
Default openfoam 1.7.1 compilation
Ehsan
ehsan is on a distinguished road
Dear Foamer
In compiling OF 1.7.1, I get the following error:
cannot find -lfiniteVolume
I had already installed OF 1.6.X in my PC and I don't thing I lack gcc, which other packages you think I lack that results in this problem?
I use ubuntu 8.04
Thanks
Ehsan
ehsan is offline   Reply With Quote
Old   October 10, 2010, 06:55
nsf
Nicolas Edh
nsf is on a distinguished road
Hi Ehsan,
As I understand OpenFOAM-1.7 needs gcc-4.3.x or later to compile while ubuntu 8.04 comes with gcc-4.2. My advice is to upgrade your distro to 10.04 which is a Long Term Support version.
If you can't upgrade talk to your admin, he'll have to install gcc-4.3 or later. You could also try to compile the gcc version that comes with openfoam-1.6 and then use that gcc to compile 1.7.
There is a good thread that you might want to check out
http://www.cfd-online.com/Forums/ope...er-ubuntu.html
The packages I needed to install on ubuntu 10.04 where
binutils-dev flex bison git-core build-essential python-dev libreadline5-dev wget zlib1g-dev cmake libpng12-dev libxt-dev libxi-dev libxrender-dev libxrandr-dev libxcursor-dev libxinerama-dev libfreetype6-dev libfontconfig1-dev libglib2.0-dev freeglut3-dev libqt4-dev qt4-dev-tools
Best of luck
Nicolas
nsf is offline   Reply With Quote
Old   October 10, 2010, 09:28
Retired Super Moderator
Bruno Santos
Greetings to all!
To complement Nicolas answer: Automated scripts for building gcc 4.4.x and 4.5.x for using with OpenFOAM 1.7 series
Best regards,
Bruno
Old   December 5, 2010, 19:52
Default OpenFoam 1.7.1 compilation
abhi25_itbhu is on a distinguished road
I am a newbie to OpenFOAM....I am trying the source pack installation of Openfoam 1.7.1. I was able to compile Openfoam without any error but when I used the utility to test the installation (i.e. foamInstallationTest), it gave me following output:
Checking basic setup...
Shell: bash
Host: ubuntu
OS: Linux version 2.6.32-26-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/abhishek/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/abhishek/OpenFOAM/abhishek-1.7.1 no no
$WM_THIRD_PARTY_DIR /home/abhishek/OpenFOAM/ThirdParty-1.7.1 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/abhishek/OpenFOAM/OpenFOAM-1.7.1 yes yes yes
$FOAM_APPBIN ...7.1/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.7.1/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...7.1/applications/bin/linux64GccDPOpt no no
$WM_DIR ...hishek/OpenFOAM/OpenFOAM-1.7.1/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.7.1/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.7.1/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...M/abhishek-1.7.1/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...1/platforms/linux64Gcc/openmpi-1.4.1 yes yes yes
Third party software
Software Version Location
gcc 4.4.3 /usr/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.22 /bin/tar
icoFoam 1.7.1 ...penFOAM-1.7.1/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
Does this output indicates a successful compilation or something is not correct?
If anybody knows about this stuff, please help me out.
I appreciate your help in advance.
Thanks
Abhi
abhi25_itbhu is offline   Reply With Quote
Old   December 5, 2010, 20:13
Bruno Santos
Greetings Abhi and welcome to the forum!
Originally Posted by abhi25_itbhu View Post
Summary
done.
Like the summary says: everything is OK
Best regards,
Bruno
Old   December 6, 2010, 21:44
Hey Bruno,
Thanks for the quick reply...!!
OpenFoam test-cases seem to be working fine so far...
Abhishek
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 21:42
Compatibility OpenFOAM 1.6 and 1.7.1 Ale_galleria OpenFOAM 2 September 20, 2010 10:14
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
