Calculation of burned gas inside tube
Old   October 9, 2010, 05:48
Default Calculation of burned gas inside tube
Algimantas
Algimantas is on a distinguished road
Hi all I'd like to calculate characteristics (flow, temperatures, etc.) of burned CNG gas (it's mainly methane) inside tube with spiral, aka turbulisator, while changing turbulisator's rotation angle. Is it possible to do that with OpenFOAM, and if yes, how? I'm compiling this software now, so as you can guess, my knowledge of how to use it is pretty poor Thanks.
Algimantas is offline   Reply With Quote
Old   October 14, 2010, 05:04
Jan Kubata
JanKubata is on a distinguished road
I think yes - it's possible to simulate your problem with OpenFOAM. For simulation of reactions (partially premixed or nonpremixed combustion) in gaseous phase use reactingFoam solver for example. You need a proper chemistry for simulation of combustion. Or you can use xiFoam based solver for flamelet-type solution for premixed combustion. It depends which one is better for your case.
JanKubata is offline   Reply With Quote
cng gas tube turbulisator
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Warning 097- AB Siemens 6 November 15, 2004 05:41
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
