stress analysis -Von Mises Theory
Old   October 7, 2010, 06:29
Default stress analysis -Von Mises Theory
hc
watashiwa is on a distinguished road
I'm doing a 2D modelling stress analysis on a typical cylinder with internal pressure
Using blockMeshDict
Solver-solidDisplacementFoam
-foamCalc components sigma
I would like to know whether I can obtain the result for Von Mises Theory. I have all the stress-->xx, yy, xy and so on but nor von mises.
In fact, in ANSYS can get the result for von mises.
Another way which I can find von mises is by taking the stress-> xx, yy and xy result as a function and put them into the von mises equation.
Not sure whether OpenFoam able to do this or not. Hope to hear from you guys if you have any idea on this.
Regards
watashiwa curious
watashiwa is offline   Reply With Quote
Old   October 14, 2010, 10:10
Default stresseq
hc
I have found out that the sigmaeq=von mises theory
I have counter check with ANSYS. not sure this is right or wrong? seems like not many people use OpenFOAM for stress analysis.
Old   October 14, 2010, 12:57
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Yes SigmaEq is the vonMises stress.
Ye there probably aren't many people that use OpenFOAM for stress analysis, compared to the amount of people using it for CFD.
But there are a few groups that I know of that use it, in Ireland (where I am) and Croatia.
Philip
bigphil is offline   Reply With Quote
Old   October 14, 2010, 13:04
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Looking at calculateStress.H, sigma_eq is calculated by
 sqrt((3.0/2.0)*magSqr(dev(sigma)))
which is the Von-Mises stress according to:
http://en.wikipedia.org/wiki/Von_Mis...ess_conditions
What does the comparison of the results from Ansys tell you?
mturcios777 is offline   Reply With Quote
Old   October 14, 2010, 13:15
bigphil's Avatar
Philip Cardiff
EDIT: misinterpreted the question.
Old   October 14, 2010, 22:01
hc
Hi ,
Hi
I did a comparison using ANSYS(classic) and OpenFOAM. The result seems to be opposite in ANSYS to what I am getting in OpenFOAM. However, both gives the same colour profile especially when I analyzed stress xx, yy, xy and von mises. Von mises in ANSYS shown identical pattern when compare with OpenFOAM.
I have verified my result thick wall cylinder in OpenFOAM with the thoeretical result which is correct but not for ANSYS. As I have mentioned the value obtained in ANsys seems not right but have the identical colour pattern. I will further investigate this.
Old   October 14, 2010, 22:57
hc
Hi Marco, how did you know the sigma_eq equation from the OpenFoam ? from which file and folder? is it require a command to execute in order to obtain the eq?
Old   October 15, 2010, 16:43
Marco A. Turcios
The file you want to look in is $FOAM_SOLVERS/stressAnalysis/solidDisplacementFoam/calculateStress.H
Checking out the source code is a great way to find out what is happening and how you can change it.
CFX-Structural thermal stress analysis Ravikiran CFX 1 February 22, 2010 09:57
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 18:06
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 15:44
stress analysis rt Main CFD Forum 0 June 7, 2007 06:01
E-Z question about Von Mises stress Andrew Epp Main CFD Forum 4 September 17, 1999 03:11
