recommended cell expansion ratio
Old   October 6, 2010, 16:24
Default recommended cell expansion ratio
guy_smiling is on a distinguished road
Hi all,
I remember reading somewhere that the recommended cell expansion ratio was between 0.833 and 1.2 from adjacent cells, but I can't seem to find that reference anywhere now. Does anyone know if there is a recommended cell expansion ratio and if there's a good reason for it?
Thanks.
guy_smiling is offline   Reply With Quote
Old   October 12, 2010, 14:15
Lars Kiewidt
LarsPT is on a distinguished road
Maybe I found something. If I use high expansion rates, i.e. high cell aspect ratios and run checkMesh -allGeometry -allTopology, I will get an error message because of small determinant of some cells. A cell determinant of 1 relates to a hexahedral cell whereas a small value relates to an illegal flattened cell. As far is I had a look at this problem the error occurs when the cell determinant is smaller than 1e-03. So one can maybe conclude to a maximal aspect ratio?
Lars
LarsPT is offline   Reply With Quote
blockmesh simplegrading
Y and Cell Aspect Ratio gdbaldw OpenFOAM Running, Solving & CFD 11 December 6, 2016 12:58
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
