October 5, 2010, 12:14 |
Jet Flow using OpenFoam
Zinedine
Rep Power: 16 |
Hi everyboy,
Has anybody have any experience in modelling jet flow and analysing CHT using Openfoam please? Thank you very much for your help and assitance. Regards Z. |
October 6, 2010, 13:44 |
M. Mahdi Salehi
Rep Power: 17 |
What is CHT !?
October 7, 2010, 04:59 |
Re: Jet Flow using OpenFoam Reply to Thread
Zinedine
Rep Power: 16 |
CHT mean Conjugate Heat Transfer. I am interested in air flow jets past objects with some kind of heat source (i.e. heat flux, temperatrure, etc..), and consequently this constitues a CHT problem. Evidently the BCS are important in this kind of analysis and was wondering if they are some available OpenFoam cases. If so I would be grateful if anybody could showm some useful links, etc.. Thanks for your help. Regards Z. |
October 7, 2010, 05:11 |
Suresh kumar Kannan
Rep Power: 17 |
Have a look at chtmultiregionFoam and rhoPimpleFoam. rhoPimpleFoam is more straightforward to set up.
regards K.Suresh kumar |
October 7, 2010, 06:33 |
Zinedine
Rep Power: 16 |
Hi Kumar,
Thanks for your reply and your suggestion. Do you have any exoperince in CHT with OpenFoam then? What do you mean by: "rhoPimpleFoam is more straightforward to set up." What is your experience in such CHT issue please? Regards Z. |
October 7, 2010, 06:58 |
Suresh kumar Kannan
Rep Power: 17 |
Hello Zinedine,
I have not studied the chtMultiregionFoam intensively but I had set up some simple cases on it for my Prof. Actually chtMultiregionFoam can be used to study problems where you have different regions like solid and fluid and you want to study the effects due to conduction in the solid and convection of heat due to to fluid. So you have a solid part solver and and fluid part solver. The solid part solver in chtMultiRegionFoam is simply the heat conduction equation (this is the entire unmodified solveSolids.H) The fluid solver, although one of the simpler, boyancy driven flow, is significantly more complex than the thermal equation. The flow equations are solved by separating flow parameters in density, pressure and velocity, solving these independently or recursively. The thermal solver for the fluid region is essentially the same as for the solid part, although the variable solved for is the thermal energy rather than the temperature, as conventions differ between solid mechanics and fluid mechanics. siince the boundary conditions have to be defined properly for the fluid region and the solid region and the interface between. You have to set a lot of things based on your problem. I think in rhoPimplefoam you solve the fluid equations only with the energy equation. You can find some explanation on the forum search for the name of the solvers. bye regards K.Suresh kumar |
October 7, 2010, 07:06 |
Zinedine
Rep Power: 16 |
Hi Kumar
Thanks fro taking the time to reply. Actually through one of the thread in CFd-online I manged to get some useful notes regarding "chtmultiregionFoam": http://www.tfd.chalmers.se/~hani/kur...08/chtFoam.pdf . Interesting brief note explaining the solver. I just wonderign if one had any experince in setting up a cse with the aforementioned sover and clearly BCs are crucial. Regards Z. |
how to simulate jet flow? | Benny | FLUENT | 18 | May 12, 2014 11:53 |
Major differences between Comsol and OpenFOAM, steady state diffuser singlephase flow | kjetil | OpenFOAM Running, Solving & CFD | 0 | November 24, 2009 20:44 |
Can OpenFOAM generate flow at the speed of light? | Michel_sharp | OpenFOAM | 6 | October 24, 2009 05:09 |
Viscoelastic flow modeling in OpenFOAM | vulda | OpenFOAM Running, Solving & CFD | 1 | March 17, 2008 08:32 |
Two Gas Jet Flow | manish mehta | FLUENT | 0 | June 17, 2005 20:54 |
