Defining "cyclic" B.C. problem
Old   March 14, 2011, 11:28
Alex
aloeven is on a distinguished road
Sorry, with this I cannot help you.
It sounds like there is a bug in the mesh adaptation or movement (I don't know what you are exactly doing). You have to check how the code handles the cyclic patches.
Since the cyclic patches should be linked, the refinement or movement should take this into account. If you change a cell on one part of the cyclic, the cell that is linked should also change in the same way.
Hope you can sort this out.
If nothing helps, you can switch to 1.6-ext and use cyclicGgi, that should work.
aloeven is offline   Reply With Quote
Problem in defining and using the deformation rate tensor titio OpenFOAM Running, Solving & CFD 0 November 19, 2009 13:50
which B.C. i should apply for this problem? raivish CFX 0 January 6, 2006 09:47
Mesh problem tuks CFX 4 May 18, 2005 15:07
problem in giving b.c kiran FLUENT 0 August 10, 2004 05:21
UDF 3D inlet b.c. problem Andrew FLUENT 4 May 25, 2004 05:24
