September 22, 2010, 06:15 |
OpenFOAM (Linux) in a MS-HPC-Cloud
Alex
Rep Power: 17 |
Hi everybody,
does anybody has an idea (or experience) , how I could run OpenFOAM from a Linux-machine, using a MS-HPC-environment? I will not cross-compile OF (spent already too much time, trying it..) but use it from Ubuntu. I would connect the Linux-machine with an MS-HPC Server and this server should then dispose the workload to the cloud-(windows)-PCs. Thank you for your help, Alexander |
September 22, 2010, 06:34 |
Anton Kidess
Rep Power: 30 |
All computers must be able to run OpenFOAM. So if you do not want to cross-compile, you'll have to set up a VM on the computing nodes.
September 22, 2010, 10:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Alexander and Anton!
Alexander: Which tutorial/guide did you follow for cross-compiling OpenFOAM? Because with the one in openfoamwiki.net (this one) you shouldn't have any problems (at least with OpenFOAM 1.7.0)! And it's compiled with MPICH2, so it should work with M$ HPC MPI! And if that goes well, you can always follow Symscape's instructions for using MSMPI with a (re)cross-compiled OpenFOAM. Now, if none of these please you, you could also send an email to Dr. Hrvoje Jasak and request the test version he has of OpenFOAM compiled natively in Windows with MSMPI. Best regards, Bruno PS - personal note: I've a grudge against M$MPI... stupid EULA... that's why I prefer MPICH2...
September 22, 2010, 18:31 |
#4 | |
Alex
Rep Power: 17 |
Thank you for your answers.
@wyldckat I used the one in openfoamwiki.net you've mentioned. I got a lot of errors with ./Allwmake. If it is the best solution to cross-compile OF, I try it again. May I post the errors to you? If so many people have already compiled OF for windows, why I can't find a download of the windows-version? There is a windows-OF (http://sourceforge.net/projects/openfoam-mswin/files/) but that is V1.5 and a lot of algorithms are missing (e.g. interfoam). I am working on Linux and prefer this system for calculating. The paradoxon: My employer is a so called "M$-Expert" and will use definitly M$ HPC . My job is to find a solution to do so.... I would be glad, if you could help me a bit, cross compiling OpenFoam. Greetings, Alexander PS Thank you also for the Symscape-Link |
September 23, 2010, 09:07 |
#5 | ||||||
Bruno Santos
Rep Power: 128 |
Greetings Alexander,
Nonetheless, both Symscape and blueCAPE have been providing the builds for a very seriously low price, so from whomever people purchase these builds, the OpenFOAM community will only have to gain from it! For more links about this subject, see here. There you will find a list of available versions for Windows and tutorials on how to build OpenFOAM for Windows. Possibly the list isn't complete. Quote:
Best regards, Bruno
September 23, 2010, 11:49 |
Good Summary
Richard Smith
Rep Power: 17 |
Good summary and history Bruno of where the unofficial Windows for OpenFOAM is at.
Alex, if you want to use Windows HPC Server to run OpenFOAM, then there is no way around the fact that you'll need to install Windows OpenFOAM binaries with MPI support on the cluster and run it there. You can find an example of how to run on Win HPC Server (using job submit) at: http://www.symscape.com/openfoam-1-7...win-hpc-server If you are struggling with cross-compiling, then consider buying Windows binaries. Surely if you employer can afford to spring for Win HPC Server licenses and a cluster, then ~$50 is nothing. The only role in this scenario I can see for Linux is if you want to setup cases or post-process results with familiar tools.
Symscape, Computational Fluid Dynamics for all |
September 23, 2010, 12:48 |
Alex
Rep Power: 17 |
Wow. What answers. On monday I will read this in detail and will decide what to do. But I can't wait to thank you for your help and understanding
THANK YOU. PS I gave your 50$-offer to our purchasing-dep. Last edited by fossy; September 26, 2010 at 12:23. |
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 05:29 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 16:39 |
Which Linux version best for OpenFOAM? | yewebis | OpenFOAM | 7 | June 10, 2009 07:31 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
