Compatibility OpenFOAM 1.6 and 1.7.1
Old   September 20, 2010, 09:26
Default Compatibility OpenFOAM 1.6 and 1.7.1
Ale_galleria is on a distinguished road
There are some problem of compatibility between OpenFOAM 1.6 and 1.7.1??
In particulary, can I use a case setup prepared for OpenFOAM 1.6 and run it under OpenFOAM 1.7.1?? and the opposite??
Thanks for your answer
Alessandro
Ale_galleria is offline   Reply With Quote
Old   September 20, 2010, 10:02
sarav is on a distinguished road
According to me you should change software and use starccm+.
Regards,
sarav
sarav is offline   Reply With Quote
Old   September 20, 2010, 10:14
akidess's Avatar
Anton Kidess
You may run into some compatibility problems. For example, the pressure formulation in interFoam changed between OF-1.6 and OF-1.7, so you'll have to spend a couple minutes adapting your case.
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 21:42
OpenFOAM 1.7.1: Oscillating CFL number LarsPT OpenFOAM Running, Solving & CFD 4 September 18, 2010 04:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OpenCFD release OpenFOAMŪ version 1.7.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2010 12:40
