simpleFoam error - calculation stopped
Old   September 9, 2010, 09:56
Default simpleFoam error - calculation stopped
Martin
RugbyGandalf is on a distinguished road
hello,
i tried to calculate the flow through two combined cylinders...
meshing tool was netgen.
it is one of the example geometries of netgen...
but simpleFoam solver always breaks the operation after 23 steps of calculation.
it points out the following errors in the terminal windows:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
in "/opt/openfoam170/applications/bin/linux64GccDPOpt/simpleFoam"
#8 __libc_start_main in "/lib/libc.so.6"
Floating point exception
could someone help me, how to get this case run?
i also postet the "0" time directory and system folder
constant folder was a bit to large
thank you very much in advance
Martin
RugbyGandalf is offline   Reply With Quote
Old   September 9, 2010, 10:29
mikael
keul is on a distinguished road
I can have a look at your problem but I need your constant folder. You could reduce the folder size if you delete all the files in polymesh exept the blockMeshDict file.
keul is offline   Reply With Quote
Old   September 9, 2010, 10:46
Martin
thank you very much...
but i do not have a blockmesh file...
the mesh was created by netgen...
but of course i could send it via email, if that would be okay..!?
Old   September 9, 2010, 10:50
mikael
No problem!
Old   September 9, 2010, 10:59
mikael
I sended you my mail by private message.
Old   September 10, 2010, 03:43
mikael
Hi RugbyGandalf!
I launched your case with epsilon = 1 and it works fine. When you work with a turbulent model the solution convergence depends a lot of your initial conditions on k and epsilon. So maybe try other values until you find good ones.
Good luck!
Old   September 10, 2010, 03:59
Martin
thank you very much
it is working great
is there a "rule" for setting epsilon and k?
what are these values saying exactly?
i am very new to cfd and openFoam - so i do not already know about all the values
Old   September 10, 2010, 04:30
mikael
I'm not an expert in turbulent model but k and epsilon depend of initial velocity, characteristic length and Reynolds number. Maybe you should have a look at some explanations you could find on Wikipedia to fix your initial conditions.
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
simpleFoam ddt Euler ? Mo-ITB OpenFOAM Running, Solving & CFD 2 June 12, 2010 13:36
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 09:42
