SonicFoam simulation probleme
Old   September 4, 2010, 18:22
Default SonicFoam simulation probleme
Alex
bruxellois is on a distinguished road
Dear Foamers!
I'm trying to simulate the exhaust of a muzzle, my mesh and my boundary conditions are ok (transient boundary condition (time-depended) ), i'm using sonicFoam (with perfect gas).
the simulation do not give any result (0 iteration all the time).
You can find my case directory here
http://www.4shared.com/file/hpAUp6tE/test64tar.html
Any help please.
Alex
bruxellois is offline   Reply With Quote
Old   September 5, 2010, 17:29
Retired Super Moderator
Bruno Santos
Hi Alex,
What version of OpenFOAM are you using and which gcc version did you use to build it?
To know the gcc version, run:
gcc -v
I haven't tried to run the case yet, but knowing the versions would help reducing the chances of "works for me, but not for you"
Best regards,
Bruno
Old   September 5, 2010, 17:35
Alex
Hi Bruno,
I'm using OpenFoam 1.7.0 and gcc version 4.4.3.
Best regards
Old   September 5, 2010, 17:52
Bruno Santos
Hi Alex,
Well, that was easy... I didn't even need to run it. The problem is that you didn't notice that your write time is larger than your end time:
endTime         0.00007 ;
writeInterval   0.0005;
Therefore, if it did write a time folder >0, then there would be something veeeery wrong
And yes, I've made this mistake too in the past
Always keep in mind that with OpenFOAM (and probably other CFD applications too), you must handle input and output data with eagle eyes Otherwise, you might end up with a GIGO case (Garbage in - Garbage out).
Best regards,
Bruno
Old   September 5, 2010, 17:59
Alex
Hi Bruno,
I've notice this error ans i modified it
ndTime 0.007 ;
But there is no change, all the simulation is with O iterations (p,e, Ux..) so the result is the same of my initials conditions. I let it working for 10 hours without any change.
Any idea.
Thanks a lot.
Old   September 5, 2010, 20:14
Bruno Santos
Hi Alex,
Let me first just warn you: I have a lot of experience in installing OpenFOAM in Linux and Windows, but sadly I don't have much experience actually using it
Nonetheless, I changed a bit the the times in the controlDict to:
endTime         0.0007 ;
deltaT          0.000008;
writeControl    runTime;
writeInterval   0.0001;
But I only let it run until it gave me a new time snapshot. The new snapshot was at 9.6e-5 seconds. Attached are the two snapshots, looking at the entrance zone and they compare U vectors with magnitude for color scale. The residues indicated that convergence is almost immediate, at least if deltaT allows for it to converge.
I can only assume two things from these two pictures:
  • the mesh could use some more refinement near the entrance... but I'm not sure about this.
  • the mesh doesn't have an outlet! If you are testing the exhaust of a muzzle, I can only assume that you don't want to compress the fluid inside the mesh volume.
Either way, if you run checkMesh, it reports a point that isn't exactly on the surface of one of the patches. Well, it's barely an error, when compared with the simulation domain...
My suggestion (as a pseudo-amateur) is to first test the mesh with icoFoam or simpleFoam, and see if the air can simply flow from one place to the other, without taking into account accuracy in turbulence and all that. Simply test the mesh if is a valid simulation domain.
Best regards and good luck!
Bruno
Old   September 5, 2010, 22:03
Alex
Hi Bruno,
Thanks for your response.
I had my mesh from a fluentMeshToFoam conversion, i've run the case under fluent and it gave a good result.
Best regards.
Old   October 30, 2010, 12:06
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
Hi bruxe
how about your simulations. explain me your problem which your are facing now. snd a private msg.
regards
Ambilpur Kiran
kiran is offline   Reply With Quote
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 01:15
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 14:24
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
simulation of tundish probleme chankhar FLUENT 21 May 27, 2006 14:46
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
