parallel error sigFpe?
Old   August 25, 2010, 07:07
Default parallel error sigFpe?
Sven Degner
sven82 is on a distinguished road
Hi Foamers,
for a parallel simulation of a naca0021 on a bluff angle (DES-LL hybrid scheme)
with a periodic boundary condition on the front and back, a fixed value inlet and zero gradient outlet the system produce this error message on a end of a Timestep:
Foam::sigFpe::sigFpeHandler(int) in "/usrfem/femsys_local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
THE SYSTEM IS STABLE FOR A COUPLE WEEKS !!!
From the forum I know also thats this error message are a random error. The most suggestions to fix this problem floatTransfer=0, unfortunately not work.
The OpenFOAM system is installed on a suse 10 the simulation crash on suse 10 and also for a suse 11 system, but not at the same time (bit later). Also the try to compile the solver on both machines (suse 10/11) doesn't work.
I'm not sure how I can handle this problem,?
The last thing is to run on a single core or a new decompose.
Hope for a clue to save this simulation.
Thank you for your help !
best regards
Sven
sven82 is offline   Reply With Quote
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM 0 May 21, 2009 01:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
