Gambit Axisymmetric Neutral File Problem
Old   August 20, 2010, 10:51
Default Gambit Axisymmetric Neutral File Problem
Sandy Stewart
SandyS is on a distinguished road
I am trying to convert an axisymmetric mesh from a Gambit mesh to OpenFoam. I have created a wedge-shaped 3-D model of a nozzle in Gambit, and have created all the 2D boundaries: inlet, outlet, frontAndBack, and top (= 5 degree curved outer surface of the nozzle). I also created a 1D boundary called "axis" from the edges along the axis of symmetry.
However, when I export a neutral file (*.neu) from Gambit (solver set to "generic") to convert to OpenFoam, it does not export the axis boundary element properly, and gives an error "Boundary entity axis does not contain any valid entity and is not written." The .neu file created has all the other boundaries defined, but not axis.
Can anyone help?
Thanks,
Sandy
SandyS is offline   Reply With Quote
Old   August 30, 2010, 17:42
Mirko Vukovic
mirko is on a distinguished road
Can anyone help?
Thanks,
Sandy
My Gambit axisymmetric geometry did not include the 1D axial boundary. Conversion to OF and simulation went fine. So you may want to delete that boundary and proceed without it.
Mirko
mirko is offline   Reply With Quote
Old   October 14, 2010, 15:43
Default Gambit Problems
Sandy Stewart
Hi Mirko,
Thanks for your reply, and sorry to take so long getting back to you. I will give your suggestion a try, but I think that is where I started, with no 1-D boundary along the axis. I'll have to check.
Cheers,
Sandy
Old   March 25, 2014, 08:01
Peter
palmerlee is on a distinguished road
Hi, Mirko!
How do you convert a gambit mesh to OpenFOAM axisymmetric mesh? Is your gambit mesh a wedge-shaped 3-D mesh or a 2-D mesh?
Kind regards,
Peter
palmerlee is offline   Reply With Quote
Old   March 25, 2014, 08:08
Peter
Hi, Mirko!
Kind regards,
Peter
axisymmetric problem, conversion, gambit 2.2.30
Gambit, Matlab & generating a neutral file ".neu" francois Main CFD Forum 5 June 6, 2020 09:34
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
GAMBIT 2.4 neutral file dex FLUENT 0 March 18, 2008 10:31
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
