icoLagrangianFoam OF1.6 myNewParticleSolver
Like Tree1Likes
Old   August 18, 2010, 10:29
Default icoLagrangianFoam OF1.6 myNewParticleSolver
heavy_user is on a distinguished road
Hi There,
i have downloaded icoLagrangianFoam and changed things so that it works on OpenFoam-1.6 (I attached it below).
I copy pasted the modified Files and added the necessary "# includes header.h" to a copy of the reactingFoam-solver...
It works all fine to a point where he tries to compile:
IncompressibleCloud cloud(vpi,U);
Then he throws at me :
myReactingParticleFoam.C:(.text+0x1aed): undefined reference to `Foam::IncompressibleCloud::IncompressibleCloud(Foam::volPointInterpolation const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)'
myReactingParticleFoam.C:(.text+0x52cb): undefined reference to `Foam::IncompressibleCloud::~IncompressibleCloud()'
myReactingParticleFoam.C:(.text+0x5f45): undefined reference to `Foam::IncompressibleCloud::~IncompressibleCloud()'
I dont know how to deal with this, since the signature of the constructor call matches the signature in in "incompressibleCloud.C".
The destructor is also defined in "incompressibleCloud.C".
So why does it work with the icoLagrangianFoam and not with the reactingFoam?
I would appreciate any help!!
THX!
p.s.:
The incompressibleCloud.C looks like this
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
  \\    /   O peration     |
  \\  /    A nd           | Copyright (C) 1991-2005 OpenCFD Ltd.
  \\/     M anipulation  |
  License
  This file is part of OpenFOAM.
  OpenFOAM is free software; you can redistribute it and/or modify it
  under the terms of the GNU General Public License as published by the
  Free Software Foundation; either version 2 of the License, or (at your
  option) any later version.
  OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
  FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
  for more details.
  You should have received a copy of the GNU General Public License
  along with OpenFOAM; if not, write to the Free Software Foundation,
  Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
  Class
  IncompressibleCloud
  Description
#include "IncompressibleCloud.H"
namespace Foam
    defineTypeNameAndDebug(IncompressibleCloud, 0);
namespace Foam {
  // * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
  // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
  // Construct from components
                       const volPointInterpolation& vpi,
                       const volVectorField& U
    Cloud<HardBallParticle>(U.mesh(),false),
    constProps_(
        IOdictionary(
            IOobject
                "cloudProperties",
                U.time().constant(),
                U.db(),
                IOobject::MUST_READ,
                IOobject::NO_WRITE
    runTime_(U.time()),
    time0_(runTime_.value()),
    mesh_(U.mesh()),
    volPointInterpolation_(vpi),
    random_(666),
    U_(U),
    smoment_(mesh_.nCells(), vector::zero),
    cloudProperties_
     IOobject
      "cloudProperties",
      U.db(),
      IOobject::NO_WRITE
    interpolationSchemes_(cloudProperties_.subDict("interpolationSchemes"))
    HardBallParticle::readFields(*this);
  // * * * * * * * * * * * * * * * * Selectors * * * * * * * * * * * * * * * * //
  // * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
  // * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
  void IncompressibleCloud::evolve() {
    smoment_.setSize(U_.size());
    smoment_ = vector::zero;
    autoPtr<interpolation<vector> > UInt = interpolation<vector>::New
          interpolationSchemes_,
        //remöved  volPointInterpolation_,
          U_
    HardBallParticle::trackData td(*this,UInt());
    label particles=size();
    this->move(td);
    this->inject(td);
    td.reportCounters(particles);
  void IncompressibleCloud::move(HardBallParticle::trackData &td) {
    Cloud<HardBallParticle>::move(td);
  void IncompressibleCloud::inject(HardBallParticle::trackData &td) {
      if(runTime_.time().value()<td.constProps().tStart_ || runTime_.time().value()>td.constProps().tEnd_) {
          return;
      scalar prop=random().scalar01();
      if(prop<td.constProps().thres_) {
          vector tmp=(random().vector01()-vector(0.5,0.5,0.5))*2;
          vector pos=td.constProps().center_+tmp*td.constProps().r0_;
          tmp=vector(random().GaussNormal(),random().GaussNormal(),random().GaussNormal())/sqrt(3.);
          vector vel=tmp*td.constProps().vel0_+td.constProps().vel1_;
          scalar d=fabs(random().GaussNormal())*td.constProps().d1_+td.constProps().d0_;
          label cellI=mesh_.findCell(pos);
          if(cellI>=0) {
              HardBallParticle* ptr=new HardBallParticle(*this,pos,cellI,d,vel);
              ptr->stepFraction() = 1;
              addParticle(ptr);
              td.countInject();
  // * * * * * * * * * * * * * * * Member Operators  * * * * * * * * * * * * * //
  // * * * * * * * * * * * * * * * Friend Functions  * * * * * * * * * * * * * //
  // * * * * * * * * * * * * * * * Friend Operators  * * * * * * * * * * * * * //
} // namespace Foam
heavy_user is offline   Reply With Quote
Old   August 18, 2010, 11:37
Assistant Moderator
Bernhard Gschaider
Originally Posted by heavy_user View Post
Hi There,
You're talking about the icoLagrangianFoam at https://openfoam-extend.svn.sourcefo...agrangianFoam/ are you?
The use of that is discouraged as since 1.5 there are facilities in OF that make most of it obsolete. If you want an example how particles can be added with 10 lines of code or so (most of those are needed to make the particle believe that they are living in a compressible solver) to a normal solvers have a look at https://openfoam-extend.svn.sourcefo...agrangianFoam/ which offers basically the same functionality
Old   August 19, 2010, 07:51
Hi Bernhard,
thanks for the answer!
I will check it out...
Best
Old   August 26, 2010, 13:37
Hi Bernhard (and other qualified persons),
so I have played around a little with it..as usual I did not get far.
I added "basicKinematicCloud.H" an constructor for my cloud and an term to the U-equation. Also a file in my case, so it knows where to inject..
It compiles and is running.
So I have some questions.
1. It does not write out any data (the tutorials write out the "lagrangian" folder as I would like it). How do I make him write the lagrangian Data?
2. the running solver says the following for each timestep:
Cloud: ParticleCloud
    Total number of parcels added   = 18
    Total mass introduced           = 0.0001
    Current number of parcels       = 0
    Current mass in system          = 0
is this a problem? Why is he not summing up ?
3. general question: where are the equations for the lagrangian particles solved/ how do the move ??
Best
Old   August 27, 2010, 05:45
Assistant Moderator
Bernhard Gschaider
Well. The the answer is:"Elvis has left the building". Elvis was the name of the 18th particle and like his 17 friends he already exited (probably through the outlet). If no particles are present no lagrangian directory gets written (have you checked all timesteps)
The answer is in $FOAM_SRC/lagrangian/intermediate/ (look for KinematicParcels and the kinematic submodels)
Bernhard
Old   August 27, 2010, 08:55
Hi Bernhard,
thanks again!
Elvis seems to be pretty quick!!
The domain is 1m. Maximum speed is 53m/sec which leads to a minimum residence time of 0.018867925 sec. Time step size is 2.5e-6sec. ..
Im a little confused..if elvis travels upstream, would be strange...of he leaves through the sidewall(wedge), but there is only the jet-spreading-velocity in radial direction(towards sidewall) so...
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 1.6-f802ff2d6c5a
Exec   : myParticleReactingFoam3
Date   : Aug 27 2010
Time   : 13:10:20
Host   : prandtl
PID    : 14967
Case   : /home/niko/Desktop/V10P1
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
// using new solver syntax:
rho
    solver          PCG;
    preconditioner  DIC;
    tolerance       1e-06;
    relTol          0;
U
    solver          PBiCG;
    preconditioner  DILU;
    tolerance       1e-06;
    relTol          0;
p
    solver          PCG;
    preconditioner  DIC;
    tolerance       1e-10;
    relTol          0;
Yi
    solver          PBiCG;
    tolerance       1e-06;
    relTol          0;
h
    solver          PBiCG;
    tolerance       1e-06;
    relTol          0;
k
    solver          PBiCG;
    tolerance       1e-10;
    relTol          0;
epsilon
    solver          PBiCG;
    tolerance       1e-10;
    relTol          0;
Reading chemistry properties
Reading g
Reading thermophysicalProperties
Selecting psiChemistryModel ODEChemistryModel<gasThermoPhysics>
Selecting thermodynamics package hPsiMixtureThermo<reactingMixture<gasThermoPhysics>>
Selecting chemistryReader chemkinReader
Selecting chemistrySolver sequential
ODEChemistryModel: Number of species = 7 and reactions = 1
Reading field U
Creating turbulence model.
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Creating field DpDt
Courant Number mean: 0.0012324 max: 0.259161
--> FOAM Warning :
    From function Cloud<ParticleType>::initCloud(const bool checkClass)
    in file /home/niko/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude/CloudIO.C at line 51
    Cannot read particle positions file
    "/home/niko/Desktop/V10P1/0/lagrangian/ParticleCloud"
    assuming the initial cloud contains 0 particles.
Selecting DispersionModel StochasticDispersionRAS
Selecting DragModel SphereDrag
Selecting InjectionModel ManualInjection
    Constructing 2-D injection
Selecting pdfType RosinRammler
Selecting PatchInteractionModel StandardWallInteraction
Selecting PostProcessingModel none
Selecting U IntegrationScheme Euler
Starting time loop
Time = 2.5e-06
Solving chemistry
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
--> Cloud: ParticleCloud
    Added 18 new parcels
DILUPBiCG:  Solving for Ux, Initial residual = 9.89937e-06, Final residual = 1.25774e-09, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 2.06847e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 3.13513e-08, No Iterations 2
DILUPBiCG:  Solving for CH4, Initial residual = 1.08956e-06, Final residual = 1.60948e-10, No Iterations 1
DILUPBiCG:  Solving for O2, Initial residual = 1.08956e-06, Final residual = 1.45812e-10, No Iterations 1
DILUPBiCG:  Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for H2, Initial residual = 1.08956e-06, Final residual = 1.60948e-10, No Iterations 1
DILUPBiCG:  Solving for C6H14, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for h, Initial residual = 1.32325e-06, Final residual = 2.00099e-10, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.99998, Final residual = 2.74215e-11, No Iterations 16
DICPCG:  Solving for p, Initial residual = 1.83512e-11, Final residual = 1.83512e-11, No Iterations 0
time step continuity errors : sum local = 2.49531e-16, global = -7.59107e-17, cumulative = -7.59107e-17
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000535399, Final residual = 6.64667e-14, No Iterations 3
DILUPBiCG:  Solving for k, Initial residual = 7.86551e-06, Final residual = 3.30353e-12, No Iterations 2
ExecutionTime = 4.69 s  ClockTime = 5 s
T gas min/max   = 292.966, 293.04
Courant Number mean: 0.00123257 max: 0.259161
Time = 5e-06
Solving chemistry
DILUPBiCG:  Solving for Ux, Initial residual = 1.04882e-05, Final residual = 1.89928e-09, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0115728, Final residual = 1.241e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.329735, Final residual = 1.26857e-08, No Iterations 2
DILUPBiCG:  Solving for CH4, Initial residual = 1.87996e-06, Final residual = 4.79358e-10, No Iterations 1
DILUPBiCG:  Solving for O2, Initial residual = 1.87996e-06, Final residual = 4.34921e-10, No Iterations 1
DILUPBiCG:  Solving for H2, Initial residual = 1.87996e-06, Final residual = 4.79358e-10, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 2.15118e-06, Final residual = 5.853e-10, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.0183647, Final residual = 4.49163e-11, No Iterations 13
DICPCG:  Solving for p, Initial residual = 2.42097e-11, Final residual = 2.42097e-11, No Iterations 0
time step continuity errors : sum local = 8.26453e-16, global = -3.35086e-17, cumulative = -1.09419e-16
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000492396, Final residual = 6.30958e-14, No Iterations 3
DILUPBiCG:  Solving for k, Initial residual = 0.000379847, Final residual = 1.27046e-13, No Iterations 3
ExecutionTime = 6.6 s  ClockTime = 7 s
T gas min/max   = 292.952, 293.088
Courant Number mean: 0.00123284 max: 0.259161
Time = 7.5e-06
Solving chemistry
DILUPBiCG:  Solving for Ux, Initial residual = 1.11296e-05, Final residual = 2.50938e-09, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.00956692, Final residual = 1.15139e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.199243, Final residual = 7.0912e-09, No Iterations 2
DILUPBiCG:  Solving for CH4, Initial residual = 2.88929e-06, Final residual = 1.05279e-09, No Iterations 1
DILUPBiCG:  Solving for O2, Initial residual = 2.88929e-06, Final residual = 9.77396e-10, No Iterations 1
DILUPBiCG:  Solving for H2, Initial residual = 2.88929e-06, Final residual = 1.05279e-09, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 3.30352e-06, Final residual = 1.25508e-09, No Iterations 1
DICPCG:  Solving for p, Initial residual = 0.00778431, Final residual = 7.47355e-11, No Iterations 12
DICPCG:  Solving for p, Initial residual = 4.86441e-11, Final residual = 4.86441e-11, No Iterations 0
time step continuity errors : sum local = 2.74574e-15, global = -4.83536e-17, cumulative = -1.57773e-16
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000844266, Final residual = 1.26724e-13, No Iterations 3
DILUPBiCG:  Solving for k, Initial residual = 0.000431396, Final residual = 1.61195e-13, No Iterations 3
ExecutionTime = 8.5 s  ClockTime = 9 s
And how do I make him write the lagrangian folder?
best!
Old   August 27, 2010, 10:29
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
thanks again!
best!
No particles: no lagrangian-folder.
Check your case-setup. Especially the injection (maybe you're shooting in the wrong direction)
Bernhard
Old   August 27, 2010, 10:36
Hi Bernhard,
me again...
I figured it out.. ELVIS does not like to sit on the inlet patch ...then he seems to be scared and does not enter the domain.
I placed ELVIS inside now and it is running fine.
Thanks again and have a nice weekend!
Cheers!!
Old   October 1, 2010, 08:19
Default icoLagrangianFoam as http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/AureliaValli
cfd_noob is on a distinguished road
I have compiled the icoLagrangian foam under OF 1.6 and I have two questions regarding this solver.
1. I am wondering why the particles are not leaving the computational domain when they reach the outlet of my test case. How and where do you define your outlet as a particle outlet too?
2. I am running into trouble running the case in parallel. Is there any known bug and/or solution to the problem?
Kind regards,
Antonio
The icoLagrangianFoam was compiled as described in:
http://www.tfd.chalmers.se/~hani/kur...m_reviewed.pdf
cfd_noob is offline   Reply With Quote
Old   October 1, 2010, 10:42
Assistant Moderator
Bernhard Gschaider
Kind regards,
Antonio
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/AureliaVallier/Tutorial_icoLagrangianFoam_reviewed.pdf
At first. I do not recommend this icoLagrangianFoam anymore (BTW: wasn't aware of this nice paper from chalmers). Since 1.5 there are better ways to implemetn particles in OF. Have a look at the lagrangian solvers that come with OF or if you want to use an incompressible solver have a look at the tutorials in 1.5-dev. There is an icoLagrangianFoam there that is basically an icoFoam with particles added.
@1: any _patch_ should force particles to leave. walls bounce it back
@2: there seems to be an issue, but for the reasons given above I never investigated it thoroughly
But all this has been discussed elsewhere on the forum. LKook for icoLagrangianFoam and sort the results by time
Old   October 13, 2010, 16:59
Hi Bernhard,
Thank you for your answer and advice. I will probably follow as you say, however I do have one question. The HardBallParticle.C .H and respective clouds are nowhere to be seen in the OF 1.6 version. Are there any alternative and similar clases I should use?
Kind Regards,
Antonio
Old   October 14, 2010, 03:25
spej is on a distinguished road
You could have a deeper look in the solidparticle.C/H or the submodels of the sprayclasses. They seems to be very similar.
spej is offline   Reply With Quote
Old   October 14, 2010, 08:37
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Kind Regards,
Antonio
As spej suggested either the solidParticle-class or the Kinematic-Parcel has the same functionality as HardBall (drag, reflection on wall, injection) implemented in a more flexible way (run-time selectable submodels)
Bernhard
Old   October 19, 2010, 11:21
Hi Senior Member,
Di you have any luck embedding the intermediate lagrangian libraries into your solver? Any example you could share? As far, i have not had any luck.
Kind regards,
Old   October 28, 2010, 04:13
Hi Foamers,
I have a very strange fault in my simulation. When I try to run a simulation with particles m>10^-12 kg the small particles stick on the wall-patch! What's wrong with my case? I vary the restitutionscoefficient e between 0 and 1 with the same results.
With heavier particles the case runs well.
Old   February 10, 2012, 09:03
Jonas L. Ansoni
Jonas Ansoni is on a distinguished road
Hi Bernhard,
I'm intending simulate a multiphase flow in a cilyndrical bioreactor. The tank is composed by a tangential inlet and an internal outlet. I plan to simulate a flow with homogeneous particles with water using one or two-way coupling. Is possible apply icoLagrangianFoam to acess this kind of flow? How I download the newest version of the solver on of1.6? Do you know any tutorial?
Thank's in advance.
Jonas Ansoni is offline   Reply With Quote
Old   February 11, 2012, 06:15
Assistant Moderator
Bernhard Gschaider
Originally Posted by Jonas Ansoni View Post
Hi Bernhard,
Thank's in advance.
As I said before: icoLagrangianFoam as described on the Wiki page has been discontinued. There is a new version in the tutorials of 1.6-ext (not the "regular" version) in the lagrangian section of the tutorials. It is basically icoFoam with some particles added. If the assumptions of that solver (incompressible, laminar) meet your requirements then you're fine. Otherwise have a look in the tutorials of 2.1 if any of the solvers there does what you need. Or you take icoLagrangianFoam from the 1.6-ext as an example on how to add lagrangian particles to ANY solver you like (mind that that solver does a trick to supply a rho-field as some lagrangian submodels assume that they live in a compressible solver)
Bernhard
Old   May 11, 2020, 05:15
SimonStar's Avatar
Simon
SimonStar is on a distinguished road
is there a version of icoLagrangianFoam that is compatible with OpenFOAM v7? Or any alternative that is only doing the additional particle tracking?
SimonStar is offline   Reply With Quote
Old   May 11, 2020, 09:46
Assistant Moderator
Bernhard Gschaider
There is a function object icoUncoupledKinematicCloud that allows adding a particle cloud to the solver
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 11, 2020, 16:53
SimonStar's Avatar
Simon
For me it is from time to time still a little cunfusing to see the differences between solvers. So thanks a lot you for answering.
Simon
Parallel using icoLagrangianFoam flying OpenFOAM Running, Solving & CFD 37 March 25, 2011 06:02
Arbitrary crack propagation using OF1.6 gilav OpenFOAM Programming & Development 1 May 22, 2010 07:52
compressibleInterDyMFoam on OF1.6 lucadauria OpenFOAM Running, Solving & CFD 2 February 24, 2010 21:18
rhoSimpleFoam OF1.6 sheintz OpenFOAM 4 September 3, 2009 08:41
icoLagrangianFoam parallelizatrion problem shchepan OpenFOAM Running, Solving & CFD 3 July 28, 2009 09:48
